General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Ive almost got all the bits togther to fully areo quip my fuel system had my spare tank modded to take aero fittings so looking for some pics to see what others have done! ive had a standard 2wd rail modded with fittings brazed on im looking to see what others have done and where you have mounted your fuel regs and what reg you have used. Also what have people done with there fuel pump / filter cradle? i have a new filter / mount and a nice ally mount for my pump so going to make a simple looking stainless cradle i think
Mark, why do you think your seeing so many problems as this is what we use regularly with success?
Could it be the boost levels your running affecting the diaphragm like the original 2wds do, as we only go to 32-34psi.
They are crap thats what I am seing 9 out of 10 will have issuses when running around 2 bar and some even before that,
Always have fuel pressure failing at the top.
Changing to centre entry with twin returns is a good mod while you have the chance.
The regulator sits where the map sensor did. Ive no idea what it is but not a Automottive i assume .
I use and have been selling Aeromotive regs without any problems for years, guess what reg my Escort has? Be aware of cheap copies though, they do look pretty well identical.
Original have the biuld date stamped on them in very small indents.
That's the route I'm going to now take rod ill get andy robinson to fit a fitting in the middle of my rail as iver end is already done
