Starting problem
Newbie to this site looking for some help
I have a 1990 H plate Erst
Been standing for a while but occasionally
starting it up
Recently it stopped starting , can't hear the fuel pump coming in on the the ignition
I have changed the pink fuel relay still nothing
Any ideas before changing pump
Thanks
starting it up
Thanks
power probe to the fuel pump and test the voltage at the pump, if you can use a switchable probe you can use it to see if it powers the pump
also check for spark as you wont get an injector pulse without a spark.
its the thing with rs turbos it can be anything
and is the relay you fitted a new item or second hand, theres a lot of dead ones for sale these days, a way of seeing if the relay is the cause is to bridge the relay and if the car starts then it needs a new one
