KONI shocks
Old Mar 15, 2005 | 09:27 PM
pee vee's Avatar
pee vee
Default KONI shocks
this may well be an un-answerable question, but!
anybody know if all the koni shocks are adjustable??
(4x4 saph) the REAR in particular, as the saph i got has konis
on it,, i can obviously adjust the fronts at the tops..
but IF the rears are adjustable at all, 'where is me knob' to do it!?
(only had a quick look tonight and cant see it lol)
cheeeeers
P
Old Mar 15, 2005 | 09:31 PM
phil4x4saph's Avatar
phil4x4saph
You have to disconnect them at the bottom bush and rotate the lower half of the shock. What a pain in the arse!!
I set mine on the hardest setting before I fitted them!!
Old Mar 15, 2005 | 09:40 PM
pee vee's Avatar
pee vee
BUGGER!
fudgeeeee,, we have a job for the weekend.!!
Old Mar 15, 2005 | 09:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yeah, sat, try and get my car mapped
sunday, is santa pod day!
Old Mar 15, 2005 | 09:54 PM
SS1's Avatar
SS1
same as above i think
ive got yellows on mine
but been told even a soft setting on them is harder than standard shocks
in the doldrums??with this post ive asked loads of times whats the best
setting for a low car "no answers"
i cracked my back wheel on a cave pothole friday night
pondering if they would have been set on soft might have saved the alloy
its set up hard all round "and to be truth full "fooker" to drive
like a gocart
Old Mar 15, 2005 | 09:56 PM
pee vee's Avatar
pee vee
ahh cheers mate. i wont go too far with them then!!
Old Mar 15, 2005 | 11:12 PM
richm's Avatar
richm
you have to compress them all the way to engage the adjusting nut inside, then twist to adjust.
They will go fookin hard at the highest setting, you won't want that on the roads round here!!!
Old Mar 16, 2005 | 12:25 AM
R4N SS's Avatar
R4N SS
i need to set my rears on hard as my exhaust scrapes when on hi boost
Old Mar 16, 2005 | 11:12 AM
lamb chops's Avatar
lamb chops
Doesnt say you need to compress them on the instructions.. must say when i ajust mine without compressing them i cant tell the diffrence.
Old Mar 16, 2005 | 11:22 AM
richm's Avatar
richm
presumably they just spin round and round if you turn them whilst extended? Certainly with mine they have to be compressed so the adjuster inside engages, and they only turn the limited adjustment amount then. You will know when you've adjusted them hard!! they are all but impossible to extend by hand on the hardest setting..
Maybe worth mentioning that the majority of the adjustment is on rebound (extending direction) only, the bump setting (compression) varies very little.
Old Mar 16, 2005 | 11:26 AM
richm's Avatar
richm
RAN, if that's the case, you need to sort the spring rates, you shouldn't compensate inadequate spring rate with damper setting..
Racey's Avatar
Racey
Phil, are you running it on the pod?????????????????
cant believe you want to adjust that ride huni, i always thought it was perfect for corners (well when it didnt spin off at brunters!!! but that was just my crazy driving he he)
Old Mar 16, 2005 | 12:46 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
racey, hopefully he will lol, or ill steal the keys
he came round last night saying it was funny in the bends and when he looked at the front dampers they were set to nearly the softest setting, so he wound em up a bit harder.
i didnt have a look cos i pissing about with my car, although at one point i heard "wheres the hammer fudgee,, oh, there it is"
so fook knows what hes done
Old Mar 16, 2005 | 04:15 PM
pee vee's Avatar
pee vee
FPMSL!!!! sounds bad dont it! hahah
RACEY.. they fronts were set pretty soft! (so i assume the rears were the same?) along the road to dads fast-ish sweeping corners and all
the car felt pretty 'wallowy' sorta thing.
Still all sorted now thanks for the help guys and gals!
Old Mar 16, 2005 | 05:09 PM
Racey's Avatar
Racey
oh cool, so thats why i spun off at brunters..... nothing to do with my driving at all
personally i always liked the ride, but great to know the ride is even better now then
Old Mar 16, 2005 | 05:17 PM
pee vee's Avatar
pee vee
i only noticed it a bit!
but yeah, shes better now!
Old Mar 16, 2005 | 05:26 PM
Billabong's Avatar
Billabong
BadCompany, it's all down to personal preference at the end of the day. I like the suspension to be quite firm, yet still have the rears on std/soft setting (Koni 'Yellow' Sports).
A mate bought an xr3i mk4 a few years ago and thought the suspension was rock hard but acceptable, he then drove my RST and couldn't understand how I could cope with the 'mega rock hard' suspension (FFS, the S2 ERST left the factory with 'hairdresser' settings )
Nov 1, 2015 06:53 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
SMILER258
Sep 28, 2015 09:04 AM
L1AM_RS
Sep 23, 2015 03:27 PM
