Saph 4x4 ecu issue
Old Mar 19, 2013 | 09:32 AM
cossiekevin's Avatar
cossiekevin
Default Saph 4x4 ecu issue
Hi guys, when i bought my Kreg saph it had a spare ecu with it as it was going to be used to install wasted spark.
After i sold the saph i sold the ecu and the buyer returned it saying the adjusting screw was missing.
Is this repairable as obviously the L8 ecu's are still quite sought after?
Thanks in advance
Old Mar 19, 2013 | 10:09 AM
daz1968's Avatar
daz1968
are you sure its level 8 with missing screw or is it a p8 ecu, if it is the buyer has had a bargain as they are worth more.
Old Mar 19, 2013 | 10:15 AM
Stu @ M Developments's Avatar
PassionFords Creator
Whip the lid off and take a picture, I will tell you what you have.
Old Mar 19, 2013 | 10:46 AM
cossiekevin
No probs ill get it up at lunch time
Old Mar 19, 2013 | 07:00 PM
cossiekevin
heres a few pics of the ecu
Old Mar 19, 2013 | 07:04 PM
The Youth.'s Avatar
The Youth.
looks like a L8 in a L6 casing
steve
Old Mar 19, 2013 | 07:13 PM
Fascinating concoction. Its a L8 motherboard installed in a L6 ecu case with the Co Screw AND its potentiometer removed and unsoldered from the motherboard.
The chip in there looks like its been in and out at least 10 times too as the bloody ink has been rubbed off the label!
On the upside, the chips specs are as follows:
Basic Calibration Specification for 5099:
  • Originally Sold: Aug 2008
  • ECU Type: L8 ECU
  • Babyboard Required: Yes
  • Encryption Key required: Yes - Green
  • Pectel or Weber: Weber.
  • Engine Type: Ford YB 2.0
  • Engine Compression: Standard
  • Head Spec: Standard
  • Camshaft Spec: Standard:
  • Injectors: Bosch 803s
  • Turbocharger: T3.48
  • Map Sensor: 3 bar
  • Intercooler: RS500 type
Additional Features Installed:
  • Closed Loop active: Yes
  • Air Injectors active: No.
  • Serial Data active: Yes.
  • Anti Lag active: No
  • Launch Control active: No
  • Flat Shift active: No
Old Mar 19, 2013 | 07:19 PM
cossiekevin
Thanks for that stu, are the co screw and potetiometer replaceable?
Also as i now have a 1990 2wd sierra is this any use to me as ive heard of l6-l8 ecu upgrades?
Old Mar 19, 2013 | 07:27 PM
If you can buy a cheap scrap L6 and send me them both I can take the pot from the L6 and fit it to that L8.
Yes - its the correct ECU for your 4x4 if your wanting it as a spare.
Old Mar 19, 2013 | 07:33 PM
cossiekevin
Sorry stuart dont have the 4x4 anymore its a 1990 2wd saph i have, i had read that the l8 could be used as an upgrade on 2wd cars?
cheers
Old Mar 19, 2013 | 07:36 PM
cheers
I must one day learn to fooking read, sorry mate.
Yes, the L8 is a good upgrade but requires the PF09 TPS to work correctly along with 2 wires reversing. Well worth doing.
Old Mar 19, 2013 | 07:38 PM
cossiekevin
Thanks mate, what is the cost involved in getting the wires changed and the new tps.
Also does the chip from my l6 fit or will it need new chip too?
Old Mar 20, 2013 | 08:35 PM
costina's Avatar
costina
Live long and prosper!!
TPS are not available at the mo. Outer 2 wires need swapping for tps but thats easy.
And yes you will need another chip to suit your spec as L6 won't work.
I'm sure Stu will clarify
Regards
Paul
Old Mar 20, 2013 | 09:41 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
At the mo your looking at Ł200 for the marelli pf09 if you can get 1 there's 3 on eBay at the mo, as for the wires ^^^ as said just a bit of rearranging
Old Mar 21, 2013 | 06:54 PM
costina's Avatar
costina
You can buy them from ducati or moto guzzi at a premium
Old Mar 22, 2013 | 11:49 AM
cossiekevin
I did see that some Maserati use them but can't imagine they are cheap!!
Old Mar 22, 2013 | 06:57 PM
costina's Avatar
costina
Lancia fiat and ferrari.
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
jdsjojo
Aug 30, 2015 07:48 PM
c20tbo
Aug 17, 2015 10:19 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
