Help engine problems rs
Old Mar 4, 2013 | 09:05 PM
goldie123's Avatar
goldie123
Default Help engine problems rs
Hello im new to the focus rs car is spluttering some times then ok its coming up these codes on my scan gauge its running direct boost forge actuator
p0234
p0002
p2000
Also just found out car has a software called tuna i would say its over fueling how do i stop it over fuelling
any ides would be great love the car and want it running 100%
thanks
Old Mar 4, 2013 | 09:44 PM
JamboRS's Avatar
JamboRS
focus rs 1672
p0234 is overboost code,normal for anything over 18psi.
could be anything from air leak on back of inlet to coil pack/leads/plugs or fuel pump.
id start with checking for air leaks as its free.
Old Mar 4, 2013 | 10:05 PM
goldie123's Avatar
goldie123
thanks for response
checked the back of inlet seems to be no leaks
just fitted new plugs nightmare cant seem to find out what the other 2 codes are tho
Old Mar 5, 2013 | 10:57 AM
Sticky.'s Avatar
Sticky.
Is it dong the splutter at 4k?
Also try maf sensor.
Old Jun 7, 2013 | 04:18 PM
goldie123's Avatar
goldie123
Well lads turns out a mad sensor and plug gaps spot on now thanks again
Old Jun 7, 2013 | 08:15 PM
stevos's Avatar
stevos
Sorry mate was it the maf or map sensor?
Old Jun 7, 2013 | 08:18 PM
goldie123's Avatar
goldie123
It was ment to say maf sensor not mad sensor haha
Old Jun 7, 2013 | 08:22 PM
stevos's Avatar
stevos
no probs mate thank. You wouldnt believe how many people who have problems with their car never post up the resolution to the fault that they had.
Glad you got it fixed mate just hope i can get mine fixed now
Old Feb 4, 2014 | 08:38 PM
lukewhite's Avatar
lukewhite
hi mate bit late reply when you say mad sensor did you just buy a new one ? I seem to have same problem ?
Old Feb 4, 2014 | 09:32 PM
lowman's Avatar
lowman
Luke....now listen..and do what we suggested
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
