Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
bloody cold starting!! where is the cooloant Temp sensor??
Old Feb 8, 2013 | 01:19 PM
kiss my shiny little RS's Avatar
Default bloody cold starting!! where is the cooloant Temp sensor??
hello all and firstly ley me appologise for my log in name (what a nob) sadly i no longer own an RS but i am still in the Ford element of the game.
anyway ... my problem.....
I have just bought an old focus off an old chap and after a couple of days of owning i realise I have a cold start issue!!
the car is a Focus, Mk1, 1.8 petol, Zetec, W reg, year 2000.
If I leave the car for a good period of time, lets say 5 hours or more it is not easy to start i.e. not right off the button and is a little bit lumpy when it does, give it 30 seconds and all is well just as you would expect.
Restarts are then perfect and take only a small flick of the key??
I have done loads of internet looking and one of the suggestions could be ECT (engine coolant temp) sensor, I am not sure and any advice would be gratfully recieved.
I have been onto the local Ford stealers and they can get me an ECT sensor (in 5 days) for circa £20 so not hte end of the world only trouble is i cant find the bugger!!
Ford said they have looked at their diagram (which in there words is pretty crap) and it is located on the cylinder head - I have have had one technician say its on the top and anotheer say it is on the cylinder head on the left side of the timing belt........?
I cannot find it in any of these locations the rocker cover only has the spark plugs on it and i cant find anything on the left side of the timing belt???? PELASE HELP!!
any suggestions on the fault and or location of the sensor would be really helpfull as Ford was about as much use as a kick in the eye.
cheers Craig
Old Feb 8, 2013 | 01:53 PM
ps it is also not in the thermoastat housing as it is the blanked off kind....
Old Mar 25, 2013 | 06:32 PM
Les Swain's Avatar
Les Swain
i need to know what the name of the sensor between plugs on ford focus X reg
manuel boeckx
13
Oct 3, 2015 02:29 PM
Derek Burleigh
Sep 16, 2015 06:27 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
