what 300mm rear disc will fit on the rear
Old Jan 23, 2013 | 06:16 PM
petemos's Avatar
petemos
Default what 300mm rear disc will fit on the rear
Hi, am looking to put a standard disc straight onto the back of my escort and use 4pot calipers. I've heard the st170 front discs will fit but I'll have to machine the hub for them to fit over.....and ideas? Cheers
Old Jan 23, 2013 | 06:35 PM
dingla rs's Avatar
dingla rs
I have st170 items on mine I just took some off the caliper an made me own brakets
cost me 40 quid all in
they fit straight on the hub its the carrier and caliper you need to take few mill off ,don't see point in machining the disc like most do as you have do it everytime you change them
Old Jan 23, 2013 | 06:42 PM
petemos's Avatar
petemos
Cheers, I tried the the standard front escort ones on and they never fitted over the hub, for some reason I thought they would be the same.... I'm putting on billet 4 hi spec calipers on......that's cheered me up...I'll get them ordered, ta
Old Jan 23, 2013 | 06:56 PM
dingla rs's Avatar
dingla rs
got mine off ebay for 19 quid discs that is
Old Jan 23, 2013 | 06:58 PM
petemos's Avatar
petemos
Well that will do me very nicely.
Old Jan 28, 2013 | 10:38 AM
ossie cossie's Avatar
ossie cossie
Any pics of these fitted.
Old Jan 28, 2013 | 12:58 PM
whizzisat114's Avatar
whizzisat114
Loving the work light Dingla
thanks for the pics aswell
Old Jan 28, 2013 | 05:58 PM
dingla rs's Avatar
dingla rs
See above mine are 300 mm
Old Jan 28, 2013 | 05:59 PM
dingla rs's Avatar
dingla rs
It's good isn't it lol
Old Aug 12, 2013 | 05:53 PM
ossie cossie
So are these the st170 front discs? and are they 300mm in diameter? Are they fitted to an escort cosworth?
Old Aug 12, 2013 | 08:25 PM
dingla rs's Avatar
dingla rs
Yes and it's a focus cosworth running escort cosworth running gear
Old Aug 12, 2013 | 09:09 PM
coswurv's Avatar
coswurv
What have you used to space the caliper from the bracket, looks like blue tube in the pic, obviously I take it it's a piece if metal tube painted blue? What length is the spacer? also what thickness is the st170 disc as apposed to the 4x4 rear disc where it mounts to the hub face, does it push the wheel out or require longer wheel studs ?
Old Aug 12, 2013 | 10:13 PM
dingla rs's Avatar
dingla rs
Think it's 14mm but unsure as car 250 miles away
At the min you need make mounting brackets aswell
Flat plate with holes in il dig you some pictures out tomro
Nite mate
Old Aug 14, 2013 | 03:07 PM
coswurv's Avatar
coswurv
You sorted any measurements mate, also what did you use to space the caliper from the bracket (blue tube)?
Old Aug 15, 2013 | 02:19 PM
ossie cossie
FORD Focus
2.0L ST170
2003 On
Front
Protex Disc Brake Rotors
Quantity Supplied = 1 pair
DR2101
Vented
Diameter: 300
Overall Height: 43.5
Original Thickness: 24
Minimum Thickness: 22
Centre Hole: 63.5
Stud Holes: 4
They say 24mm thick did you have to do anything to the calipers to get them to fit? As i thought cosworth std rear disc,s are 20mm thick.
Old Aug 15, 2013 | 02:27 PM
whizzisat114
You have to tak a few mm off iinside of carrier to accept disc
And make brackets to hold caliper in new position
Old Aug 15, 2013 | 07:05 PM
dingla rs's Avatar
dingla rs
the blue part is tube tured down to 14mm If I remember and as dave says you need take some off the carrier ,my car is with ^^^dave above if you need some measurments
Old Aug 15, 2013 | 07:25 PM
costina's Avatar
costina
Live long and prosper!!
I'd be making the brackets a minimum of 8mm thick tho to reduce flex
Old Aug 18, 2013 | 06:28 PM
coswurv's Avatar
coswurv
Did you have to make longer brake lines? Also does the handbrake cable still fit ok and clip into the rear arm brackets like normal?
Old Aug 18, 2013 | 07:52 PM
Marc sierra's Avatar
Marc sierra
Have the calipers also been modified? Or do they still fit the thicker discs, even with new brake pads?
Old Aug 23, 2013 | 10:04 AM
coswurv's Avatar
coswurv
Well I've got mine fitted, I'm just having some brackets possibly laser cut depending on price, may be able to offer a kit,
Old Aug 23, 2013 | 10:36 AM
MrC's Avatar
MrC
A kit would be Ausome
Old Aug 29, 2013 | 09:22 PM
Blueberryhaze's Avatar
Blueberryhaze
I will buy the kit happily pal!! Get them made
Old Sep 2, 2013 | 07:37 PM
Marc sierra
A kit would indeed be very nice!
Old Sep 2, 2013 | 07:53 PM
dingla rs's Avatar
dingla rs
can see how easy the plate is to make on mine here 14mm spacer and some machining on the caliper and carriers
Old Sep 17, 2013 | 08:23 AM
Cool mod that Dingle.
Old Sep 17, 2013 | 03:17 PM
drsrst2zvh's Avatar
drsrst2zvh
I think Coswurv is offering a kit over on the escortcosworth forum, using laser cut alloy brackets.
Old Sep 17, 2013 | 04:10 PM
7sean7m7's Avatar
7sean7m7
Not meaning to sound stupid so apologies if it is, but isn't the pad only touching like half of the disc?
Old Sep 17, 2013 | 04:20 PM
coswurv's Avatar
coswurv
Yes it does, but all 300mm set ups that use the original caliper are the same, unless you buy bells and rotars. Best way to stop any corrosion in the unswept area is to mask it up and dust over it with some matt lacquer.
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
Red_bull
Aug 9, 2015 08:34 AM
Graceland
Jul 31, 2015 10:34 AM
