88' Sierra 2.0i fuel pump not working
Old Jan 12, 2013 | 02:52 PM
baltais13's Avatar
baltais13
Default 88' Sierra 2.0i fuel pump not working
Hello!
I have an 88' Ford Sierra 3-dr 2.0i OHC KAT engine. Two days ago in the evening I was playing with my Sierra in deep snow and then drove home. The morning after I could start it but after 200m engine stopped and then I could not start it. Afterwards I noticed that when I turned key to position II (when both red - handbrake and oil pressure bulbs appear) fuel pump did not make the sound (that lasts about a second or two) that it usually did.
So I guess that electricity does not reach it OR it stopped working for some reason.
What could be the problem?
I checked both engine management relays (in position D (brown) and postion XI (red)) and they are working properly. Fuse is not blown. I also pushed inertia switch and still nothing. Then screw the switch out and checked if it worked properly and it did.
How can I check if fuel pump itself is dead? Besides replacing it with another one (cause I don't have it)?
Old Jan 12, 2013 | 03:12 PM
martysmartie's Avatar
martysmartie
Run power directly to the pump, if it dosen't run then the pump is no good, if it runs then you have an engine management/wiring or relay problem.
Martin
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
