Mk2 focus rs running problems please help
Old Jan 2, 2013 | 09:03 PM
Alfieb3204's Avatar
Alfieb3204
Need to get my mk2 finish
Default Mk2 focus rs running problems please help
Hi I'm new but I have a focus rs mk2 and I'm having running problems it's popping and banging when coming on to high boost only mods I've done is k&n pace intercooler samco forge actuator and turbo...
Old Jan 2, 2013 | 09:16 PM
GUZZLER's Avatar
GUZZLER
Has the map been altered to suit the actuator and turbo?
Old Jan 2, 2013 | 09:20 PM
Alfieb3204's Avatar
Alfieb3204
I've only changed the turbo actuator and recirculating valve to forge ones not had it mapped yet
Old Jan 2, 2013 | 09:23 PM
Jay,'s Avatar
Jay,
Sponsor
Boost cut limit being hit my guess
Old Jan 2, 2013 | 09:27 PM
Alfieb3204's Avatar
Alfieb3204
But if I blank off the dv it runs fine
Old Jan 2, 2013 | 09:29 PM
Jay,'s Avatar
Jay,
Sponsor
Maybe the valve is leaking !
Are you sure it's working correctly
Old Jan 2, 2013 | 09:34 PM
Alfieb3204's Avatar
Alfieb3204
Na I dont think its leaking I'm on my third one now cozi was thinking the same do you think it could be cos I got a recirculate valve on the turbo and a dv valve
Old Jan 3, 2013 | 02:15 PM
pee vee's Avatar
pee vee
You've got what? Essentially you've got 2 dump valves then.. Just one shoves all the noise and air back into the system.
It'll be a Problem with how it's all fitted.
Old Jan 3, 2013 | 03:48 PM
Alfieb3204's Avatar
Alfieb3204
Yer there's one in the turbo on the mk2 rs and I got one with the samco kit I put on so I fult that's what they run so should I take that one off and just run the one in the turbo
Old Jan 3, 2013 | 03:57 PM
pani_k's Avatar
pani_k
PassionFORD Member
It isn't running right because of your atmospheric DV fitted on your Samco kit, you are messing the fuelling up with it. Keep to your forge recirc and bin the other one.
Old Jan 3, 2013 | 04:28 PM
andy888's Avatar
andy888
what he says
Alfieb3204's Avatar
Alfieb3204
Cool thanks has anyone fitted the forge recirulation valve blank on the mk2 rs
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
saph in dorset
Aug 14, 2015 10:10 AM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
