ST220/Focus RS alloys.
Does anyone know if an 18" ST220 alloy will fit a MK1 Focus RS? I know a lot of FRS owners will use an ST170 space saver as a spare but apparently this only fits the rear wheels as the front brakes are too large for the space saver to go over them. I don't like relying on the standard puncture repair kit because if the tyre suffers an impact a puncture kit aint going to be a lot of use.
Next question, will an 18" wheel and tyre fit in the spare wheel well?
Not to sure if one fits in the spare wheel well I just keep mine in the boot you would have to get the boot padding from a ghia for it to fit depth wise but ill try my spare in the well in the morn and let you know you can fit a st170 alloy over the standard brembos if that's any help to ya tho
if you get a puncture on the front,jack car up on that side remove rear wheel,put on front and then put the spacesaver on back.
i got a front puncture few weeks back and used the spacesaver
if an 18" mondeo fits in the spare wheel well is it not best to have a spare frs wheel instead?
why not use the spacesaver?
Regarding your last sentence about the FRS spare wheel, this might sound a bit blond/thick but that did occur to me when i posted the thread up originally but i thought i might be able to pick up a cheap secondhand ST220 alloy easier and cheaper than an RS wheel.
I was just wondering if it was possible of minimising the possibility of having to change 2 wheels if i got a puncture on the front (rear alloy to front then space saver on rear).
