Ka 1.3 Rally Car Build LHD
Old Dec 17, 2012 | 07:43 PM
smudger068's Avatar
smudger068
Default Ka 1.3 Rally Car Build LHD
Okay so I will begin my second build (the first was a Mk1 Mini)
I have an Ex- KA Championship Left hand rally car
Thing is it is in complete pieces and not all the parts are there
So I collected the car and it looks like this:
After getting all the parts out, filled the Ka and my focus with Ford racing bumpers and general shite
Then I began to inspect the 1.3 engine: High Comp pistons, 285 Spec Camshaft, 3 angle Valves and Seats, higher IB springs and lightened flywheel
And this is what it looked like when i got it:
With a general check on measurements crank float etc all was good
Then the engine was sent to Scholar Engines for a clean up so here goes:
- New Piston Rings - New Shells - New Gaskets and Seals - A Hone - Crank Polish and thorough clean
So relapped valves and started to rebuild the head. Had OCD on keeping it all clean, tools the lot:
Then began to clean the pistons:
Spent a day cleaning the engine cases, crank bolts, push rods etc:
Then bagged everything up ready for final build at another location, fully mapped ECU, and speedline Corse wheels
Old Dec 17, 2012 | 07:49 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
i looked after Gambles KA for a few seasons
cracking cars
Old Dec 17, 2012 | 08:04 PM
smudger068's Avatar
smudger068
Excellent a few questions:
Was the immobilser activated as i havent got a key?
What power am i expecting some say 90 some say 100, honestly i was hoping for 95?
I currently run with Tony Clements Evo at the moment and just wanna drive myself!
Thanks lee
Old Dec 17, 2012 | 09:01 PM
SMILER258's Avatar
SMILER258
Looks ace, good luck with it all
Old Dec 17, 2012 | 09:29 PM
Cossie Sean
to be honest, we had many many issues with ECU and wirning, kept melting pistons!
this is the reason it retired as we changed ECU`s, injectors, etc etc etc even complete harness!(i later found he`d been having the heads skimmed to death without saying anything.........)
PATS was removed as it was origional Motorsport ECU, well it was a new bought car to be fair.
i personally, would fit a 1.4 Zetec....... the 1.3 is just pitiful matey all IMO ofcourse
we were close with Chris Birkbeck rallying and they did the 1st conversion with bits from us, car was a totaly amazing, well balanced grin machine!
they were "about" 100bhp, never felt like it, but would still put a grin on your face
Old Dec 17, 2012 | 11:07 PM
Brian's Avatar
Brian
Nice project
Brian
Old Dec 18, 2012 | 02:40 PM
smudger068's Avatar
smudger068
Excellent thanks for that
To be honest, i was seriously considering the conversion but considering the engine was so good, and didnt cost much to get it rebuilt I thought id get the use out first, get the car built and then go from there.
The reason i asked about the ECU is because it looks like an original ECU (silver case) unlike the black Ford Racing ones i have seen so was a little confused
Old Dec 18, 2012 | 03:52 PM
Cossie Sean
ours were silver too, look for paint on the hex head screws and stickers from Ford Racing, in red i think
injectors were 2.0 mondeo i think to
Old Dec 18, 2012 | 03:55 PM
smudger068's Avatar
smudger068
Excellent Cheers
Old Dec 18, 2012 | 04:12 PM
Cossie Sean
ive still got this worn out T shirt aswell from the launch etc
Old Dec 20, 2012 | 09:29 PM
smudger068's Avatar
smudger068
Default Ka 1.3 Rally Car Build LHD...Engine Build
okay so today I got on with assembling the bottom end considering i have never done this before took me a while to get as far as I did nevertheless i bloody enjoyed it serious cleaning OCD though
okay so to begin: Retapped and freshened up all the threads including water pump etc etc
A swift brake clean, clearing galleries etc etc
Then i checked the ring gap for all 3 rings in all 4 bores
Had to do some filing as some were a lil tight
Ready for assembly
Inserted new shells
I used grathogen not oil as the engine is going to be standing for a while
In with the crankshaft
A torque down
then assembled the timing chain and end covers with brand new seals and gaskets
This was enough for one day, so will continue tomorrow as i have still got to get the sump bolts
Old Dec 22, 2012 | 10:48 AM
Cool project. Will keep an eye on this.
Old Mar 19, 2013 | 06:06 PM
gjh's Avatar
gjh
Nice project this (I am a bit slow in finiding it though). Any updates?
Old Mar 19, 2013 | 06:30 PM
smudger068's Avatar
smudger068
The project is not being undertaken, well not by me anyway as i believe its to expensive to build to a respectable state, plus the cage is being used for another KA and the master cylinder has corroded so its not continuing
Old Mar 19, 2013 | 06:38 PM
gjh's Avatar
gjh
Bummer!! Sorry to hear that.
Old Mar 19, 2013 | 07:13 PM
wellens7's Avatar
wellens7
are you breaking the ka ?
JoeyBoyden
Jan 4, 2024 02:36 PM
matman
Sep 9, 2015 05:45 PM
Sultzi
12
Aug 16, 2015 01:08 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
Bobby9779
Aug 11, 2015 06:47 PM
