05 Mondeo 2.0 TDCI Limp home mode issue
Hi,
I have a 2005 TDCI Mondeo LX, 122k miles. I recently had the car serviced and not long afterwards it began to go into limp home mode. This happens after some motorway driving and normally when accelerating away from a toll booth at around 50-60 mph and in 4th or 5th gear. At slower speeds its fine. It doesn't matter if I'm accelerating hard or soft it still happens, but not on a regular basis, sometimes it happens other times it doesn't.
I've had the injectors and egr cleaned and the car feels great until the limp home mode occurs. The mechanic was able to recreate it under hard acceleration and is now a bit stumped as to what is causing it. He did have a similar issue with another mondeo which turned to be the fuel suction pump, but that car was in bad shape.
Any help would be great as a new fuel suction pump is an expensive job.
Diagnostic fault codes that showed up are as follows:
P1211 Inj. Ctrl Press. High/Low (Eng. On)
P2291 Injector Control Pressure
P0251 Injection pump A
Could be any number of things, and needs a proper diagnosis by a diesel specialist unless you want to keep fitting parts.
The two main culprits are the inlet metering valve (on the pump), and the fuel pressure regulator (on the end of the fuel rail).
Surprisingly, even a duff fuel filter can cause a similar issue.
JK12
33
Apr 26, 2021 12:09 PM
