Zetec turbo HG failure advice
Old Nov 6, 2012 | 08:00 PM
nevsrevs's Avatar
nevsrevs
Default Zetec turbo HG failure advice
After having ongoing pressure problems in the cooling system, we thought we would pop the head off this is what we found,
Now why? Head lift, det damage, too hot, or just dodgy gasket?
We did run just over 2 bar on a t38 407hp, genuine st170 gasket.
What's your thoughts guys?
Old Nov 6, 2012 | 08:07 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Maybe just unlucky mate, dont hear of many head gasket failures on theses really.
Old Nov 6, 2012 | 08:44 PM
nevsrevs's Avatar
nevsrevs
Now we are thinking that we lifted the head, it's been pressure tested and skimmed today, so we will try again with some arp studs this time.
Old Nov 6, 2012 | 08:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
what type of gasket is the st170 mate? MLS?
as i used a focus RS MLS on mine and that was 28psi 397bhp/386lbft with focus rs head bolts
granted i only done about 200 miles in it tho
Old Nov 6, 2012 | 08:52 PM
crazycage's Avatar
crazycage
gasket looks like it just got hot mate but that could of happend after it let go. did you use gen ford head bolts ? and did you torque them down to silvertop settings or blacktop ?
Old Nov 6, 2012 | 08:54 PM
crazycage's Avatar
crazycage
all blacktop head gaskets are mls only the silvertop has the shity fibre gasket
Old Nov 6, 2012 | 08:58 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ah ok mate. as said i used the std frs one and bolts but didnt have the car on the road long.
it was nigh on flat out for that 200 miles tho lol
Old Nov 6, 2012 | 09:01 PM
nevsrevs's Avatar
nevsrevs
Yea gen 4 layer gasket, pattern bolts though, but was told that would not make much difference? We seem water temps of 105C on the dyno is that enough to harm it?
What ever did it, it happened whilst mapping, and only was a niggle when on track that it use to push water out the header cap, at least it's not a cracked head!
Old Nov 6, 2012 | 09:03 PM
nevsrevs's Avatar
nevsrevs
Yea Gary set torqued down to Ian's spec of three then 105 degrees to finish
Old Nov 6, 2012 | 09:04 PM
crazycage's Avatar
crazycage
na 105c is nothing on a zetec
Old Nov 6, 2012 | 09:09 PM
nevsrevs's Avatar
nevsrevs
Think it must be head lift then? Stuck in a catch22 now strip completely and go m12 or stick some arp's in it and go again?
Old Nov 6, 2012 | 09:16 PM
crazycage's Avatar
crazycage
know how you feel. ive just done a m12 conversion on mine but only because its in bits lol.never had a problem the way it was but planning on running more power through it next year
Old Nov 6, 2012 | 09:23 PM
Dicko&Vacant
As I said in other thread I asked Ian about doing the m12 bolts, he said no need to jump on bandwagon lol he's never had an issue with head lift if good quality parts are used.
Old Nov 6, 2012 | 09:42 PM
nevsrevs's Avatar
nevsrevs
Think we will give the arp,s a shot and keep our fingers crossed, never going to be pushing the boundarys on the power front just want a reliable motor! At least the manifold good now!
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
