focus tddi common problems?
Old Nov 2, 2012 | 12:18 PM
BigChuck's Avatar
BigChuck
Default focus tddi common problems?
I'm going to look at a 2000 y focus, are there any common problems on these i should be looking out for?
Old Nov 2, 2012 | 02:47 PM
vaughant's Avatar
vaughant
Guy in work had one and again pump/injectors on a one owner 100k mile car,cost a few £££ to sort but their a lot more robust than the useless mondeo mk3 tdci contraptions.
General faults are few,the dash electrics play up sometimes and I'm not 100% but I think there may be a rear bush issue as they get higher miles but the car in general is a really well put together bit of kit,loved my 1.8 zetec estate,drove like new on 130k.
Old Nov 2, 2012 | 05:54 PM
220tel's Avatar
220tel
ive had mine for 5 years and apart from tyres and a boost pipe coming off its been faultless
sitting at 154k now doesn't use any oil or water
Old Nov 3, 2012 | 06:48 PM
Twizz's Avatar
Twizz
Out of many, we are one.
Bought ours a good few years back, reached 150k before the injector pump went. Started struggling to start in the mornings so changed the glow plugs and the diesel filter but eventually got it down to the injector pump.
Edit: Sourced a 50,000 engine, box and ECU and plumbed it in. That was 30k ago..
Thats all really I've ever had go wrong, the odd power steering pump (after a year the replacement one gave up) and a little bit of rust on the bottom of the rear doors - apart from that shes a beast.
Old Nov 3, 2012 | 11:40 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Throttle pedal/potentiometer. makes it go into limp mode then turn ignition on and off and all is well again
Old Nov 4, 2012 | 06:24 AM
Twizz's Avatar
Twizz
If you hold the trip button down, then turn the ignition on. You can filter though the various modes until you get to DTC - that'll show up the error codes (but you need to take a book etc to decipher them).
On the previous engine I was losing water near the thermostat housing.
Old Nov 4, 2012 | 06:50 PM
The pumps are common for going faulty as said above.
Old Nov 4, 2012 | 07:30 PM
BigChuck's Avatar
BigChuck
in the end, i bought my self an astra van, it popped up local and cheap. that should see me through the winter
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
muffster
13
Sep 3, 2015 09:40 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
marky_g
Aug 19, 2015 11:46 AM
