Supra diff conversion
Old Oct 21, 2012 | 11:19 PM
SapphyMike's Avatar
SapphyMike
Default Supra diff conversion
How much are they? What does it consist of?
Old Oct 21, 2012 | 11:58 PM
Ginge's Avatar
Ginge
www.virtualseason.net
Give Turbosystems a ring, Tony does these I believe.
Ginge
Old Oct 22, 2012 | 03:10 AM
Lowson's Avatar
Lowson
What's the benefit of this conversion? Just stronger and capable of more power? Is there much to the conversion?
Never looked into this and am quite intrigued.
Old Oct 22, 2012 | 11:39 PM
Ginge's Avatar
Ginge
Diff mounting points need changing and flanges iirc.
Ginge
Old Oct 23, 2012 | 06:57 AM
scoooby slayer's Avatar
scoooby slayer
the benefit is the strength of the diff, i have run 760 rear hub hp 650 rear hub lb ft torque through a supra diff, it had a carbonetic lsd but crownwheel and pinion where stock and it never broke, it also ran 295/30/19 r888 rear tyres and clean hooked in third in the dry, ive had a few cossies and i dont personally think any 7.5" cossie diff no matter how its uprated would take that ammount of power.
Old Oct 23, 2012 | 09:00 AM
fraser9764's Avatar
fraser9764
Ginge
Its all bolt on bits.
Old Oct 23, 2012 | 09:42 AM
adriankt77's Avatar
adriankt77
I have one waiting to be fitted at the moment. Its ment to be a straight forward swap / bolt in mod .
It comes with all flanges/brackets nuts an bolts for fitting ..
Old Oct 23, 2012 | 09:53 AM
SapphyMike's Avatar
SapphyMike
Where did you get the kit from?
Old Oct 23, 2012 | 10:05 AM
Cossiemainful's Avatar
Cossiemainful
Would recommend this conversion without any doubt.
Know about some broken supra diffs but those ppl have to rethinking their style of driving I guess. A supra diff is very very strong and will take much abuse before it's gone.
Old Oct 23, 2012 | 07:05 PM
adriankt77's Avatar
adriankt77
Tony at Turbosystems sorted mine out .. Don't no if anyone else can help
Old Oct 23, 2012 | 07:43 PM
Cosnada's Avatar
Cosnada
I've got a diff here and just need the in and output flange adaptors. Who sells just these as I don't want or need to pay for a complete kit with diff.
I have got to make my own mounts as I am not using a cossie hoop.
Old Oct 23, 2012 | 08:12 PM
SapphyMike's Avatar
SapphyMike
Cheers! I have contacted him on here, and would call him but I can't seem to find a turbo systems website anymore?
Old Oct 24, 2012 | 09:21 AM
adriankt77's Avatar
adriankt77
Try calling tony on this number .07587 188434.
If he don't answer send him a txt he will get back to you
Old Oct 24, 2012 | 09:58 AM
COCHYN's Avatar
COCHYN
Same here mate, nobody seems to want to help out by just providing the adapting parts, they wanna charge silly amounts on top for a diff that only costs about £100 from a scrappy
Old Oct 24, 2012 | 11:15 AM
Cosnada's Avatar
Cosnada
£1K or nothing
How about - £300 for a fitting kit and we are all happy
Old Oct 24, 2012 | 11:30 AM
scoooby slayer
tbf if i had designed and made up a conversion kit i wouldnt sell off the main conversion parts cheap without the kit, unless the mark up was still good on the parts. mkiv supra tt diffs still fetch good money though tbh.
Old Oct 24, 2012 | 12:00 PM
COCHYN's Avatar
COCHYN
It's the MK3 diff 3.73 ratio that we need anyway, and they're dead cheap and common. But I understand the reasoning for it, but you're basically paying £900 for flanges and mount
Old Oct 24, 2012 | 12:45 PM
MK MOTORSPORT's Avatar
MK MOTORSPORT
hi what is it you need just the shaft adapters
mark
Old Oct 24, 2012 | 02:00 PM
COCHYN's Avatar
COCHYN
Aye Mark, but you said you wouldn't be making them though since other do already
Old Oct 24, 2012 | 02:06 PM
MK MOTORSPORT
hi
will do the shaft adapters ,as i have started fiiting supra diffs in my rear cradles ,but the plates to bolt them in a standard beam i wont be doing
mark
Old Oct 24, 2012 | 03:04 PM
scoooby slayer
ah i thought it was mk 4, yeah they are mega cheap.
Old Oct 24, 2012 | 03:43 PM
lee2cossies's Avatar
lee2cossies
I'd be interested in just the adapters for drive shaft too.
U can also use the mk2 supra diffs, turbo have the LSD and these are the ones they use in America.
Old Oct 24, 2012 | 04:02 PM
COCHYN's Avatar
COCHYN
But we need the one's closest to our ratio or you'll be forced to change bits in the box as well. So the 88-92 MK3 Supra 3.0 Turbo or N/A with the 3.74.1 diff is what us RWD boys need
@ Mark
I know mate, but I need the adapters for a standard beam Can you PM me a price for the CV adapters please mate, I might be able to make brackets out of stainless to mount.
Old Oct 24, 2012 | 04:34 PM
lee2cossies
The mk2 turbo diff is 3:73:1 so that's pretty close!
Old Oct 24, 2012 | 04:58 PM
GINGExR2 T's Avatar
GINGExR2 T
Anyone got a picture of one fitted into the standard axle.....Please
Ginger
Old Oct 24, 2012 | 05:08 PM
COCHYN's Avatar
COCHYN
I think I may have done a typo, it's the same diff then
Old Oct 24, 2012 | 05:21 PM
lee2cossies
Yeah apparently so. If not then I have 2 expensive door stops!! Iv got a list of the ratios from different models I'l post it up when I get home.
Old Oct 24, 2012 | 05:57 PM
Cosnada's Avatar
Cosnada
It's the mk3 turbo - 3.73:1
Mark,
Will deffo have a pair of output flange adaptors off you. I did enquire but was not ready, am now
Do you do an input flange adaptor too? Would take all 3. I wanted both drive shaft pcd's so that I can retain small cv's if necessary eg 100mm and 108mm.
Old Oct 24, 2012 | 07:14 PM
COCHYN's Avatar
COCHYN
I looked at my beam earlier and the mounts I can sort, but I'll need the flanges off you too Mark
Old Oct 24, 2012 | 07:27 PM
Cosnada's Avatar
Cosnada
That's 2 of us then!
Old Oct 24, 2012 | 07:56 PM
750hp escos's Avatar
750hp escos
Thats 4 off us!!lol
cheers danny
Old Oct 24, 2012 | 09:52 PM
lee2cossies
5 of us!!
Old Oct 24, 2012 | 10:22 PM
Sonic Boom's Avatar
Sonic Boom
Make it 6 i'll have a set of flanges too.
Rich
Old Oct 25, 2012 | 12:08 AM
Cosnada's Avatar
Cosnada
Mark............... lol
6 customers waiting
Old Oct 25, 2012 | 04:57 AM
COCHYN's Avatar
COCHYN
I'm still waiting......
Old Oct 25, 2012 | 05:17 AM
MK MOTORSPORT
hi ok
i will do them can someone post a pic of the diff please just to see if its the same as the one i am fitting in richis cradle
thanks mark
Old Oct 25, 2012 | 07:06 AM
adriankt77's Avatar
adriankt77
Some pics on eBay item number 170917701316
Old Oct 25, 2012 | 07:32 AM
MK MOTORSPORT
hi
just a thought does anyone know if the other conversions take into account that most cars will be lowered so by lifting the diff in the beam when making plates will regain the proper drive shaft angles so plunge remains as standard and joints have a easier time , might be worth considering
mark
Old Oct 25, 2012 | 08:23 AM
BRAMMER's Avatar
BRAMMER
I'm interested to see where this goes, if something can be put together between traders and members i'd be in for a conversion kit. I turned down a diff months ago as i couldn't get the fitting kit seperate, think the diff was only £150
Old Oct 25, 2012 | 09:53 AM
Cosnada's Avatar
Cosnada
Here you go Mark - the small pic is the 3 litre turbo mk3 diff.
The large pic is from an american conversion and looks to have the 2 sets of cv joint bolt pcd configurations.
HTH - when do you need deposits? Maybe a list of buyers should be started?
