Dual Mass Flywheel Problem
Old Sep 3, 2012 | 09:48 AM
steffan1's Avatar
steffan1
Default Dual Mass Flywheel Problem
Would love some advice please.
While on holiday the dual mass flywheel went. The cost of repair was £900 and it came with a 2 year warranty. Now i've noticed the same symptoms again including the starter motor has had to be replaced. Problem is the garage is 200 miles away and he said on the phone its possible they would have to keep the car 2 weeks and there's a chance the warranty wont pay out.
Any advice would be really welcome as i haven't got a clue what to do.
Old Sep 3, 2012 | 12:12 PM
JOHNDQ's Avatar
JOHNDQ
Whats the fault... Dust causing starter to fail???
Old Sep 3, 2012 | 01:03 PM
steffan1's Avatar
steffan1
Ye. Was making grinding noise on start up and now started doing exactly the same thing.
Old Sep 3, 2012 | 06:46 PM
JOHNDQ's Avatar
JOHNDQ
Odd They normally make a noise on idle or when you switch off the engine
Old Sep 4, 2012 | 08:58 PM
cossie.con's Avatar
cossie.con
Can you not ask if you could have the car inspected by a local garage and then they send them a report as it is obviously putting you out to even suggest that the car needs to go back to them? Who is to cover the cost in fuel down time with work commitments etc if it does prove that the part is faulty?
Mik
Old Sep 7, 2012 | 11:32 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
They may not have cleaned the starter out. I'd do that and see if it makes a difference. I'd also document EVERYTHING you do with the garage and be prepared to take it legal. If their repair has failed then THEY'RE liable for the repair, nothing to do with the warranty - as long as they supplied and fitted the parts.
Old Sep 7, 2012 | 12:17 PM
daviddunlop83's Avatar
daviddunlop83
Whats the best way to clean it out?
Im going to be replacing my DMF in couple weeks
Old Sep 7, 2012 | 03:05 PM
DanW@FastFord
Spelling Club King!
Take it off and blow it out with an air line. It's just swarf from the DMF breaking down.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
