out to test if efi cvh is getting fuel?
As above rely how can I test that I'm getting fuel in the inlet and at the plugs other than taking plugs out and seeing if there wet? If there is no fuel what are common probably
I have already changed pump and sender are it prime clicks and stops when u turn ignition
crack off fule filter 17mm n prime it up n turn it over til u see u get fuel, if u dont but the pumps priming then persevere until it comes up as it shud eventually. if got fuel ther, go to inlet feed nx to injector one (on left of rail) its a 19mm, undo completely n repeat process. if u got fuel then go to the return off the regulator and repeat. if u got no fuel make sure its priming, if so in the tank thers a diaphram in the pump that dictates fuel oressure.... make sure the seals are good as if they leak then ul never get pressure to get fuel up the lines. hope this helps, its a start!
Remove injectors from the intake, leaving them clipped into the fuel rail and crank the engine over. If fuel sprays out, then you can be sure fuel is getting injected into the engine.
The other suggestions may prove the fuel pump is working, but that's about it.
Of course if you have confirmed fuel pressure and fuel flow, you could just use a test noid light or suitable multimeter or scope to test for a signal at the injectors.
Although that is only a test for an electrical signal, it still wouldnt mean the injector is spraying ( although usually you would take for granted it is )
There will be an ign 12v live when key is on. And a pulsed ground signal from the ecu which opens the injector.
A digital voltmeter may give you an indication of signal when set to dc volts. Depends on it's response time.
deally you want to use duty cycle or pulse width though. Or use an oscilloscope which will give you either of those to verify a signal
http://www.2carpros.com/articles/how...-fuel-injector
JK12
33
Apr 26, 2021 12:09 PM
