car not starting **now started**!!!
thanks lads for the ones that helped me out.. was appreciated
right, car was booked in today for some general maintenance at the garage.. check a few things out
and Ive gone to start it, and the fooker will not start
Definatley has fuel
Is cranking over fine
Full Battery
But doesnt want to seem to start, you know when it doesnt fire
Any ideas people... the feul pump is priming
Definatley has fuel
Full Battery
mines having very similar problems and even with a tow it wouldnt start. been told it could be the fuel distributor thats gone
edit: this was after the engine started first time about an hour b4 and the engine was still luke warm wen we had to tow it
its FUCKING COLD out today... cold enuf so that you may actually need the cold start valve working! lol
has yours been removed?
altho saying that, it should still catch...
cold start not connected..
just checked for spark... and no spark
could be that i let the plug get a litle wet tho as its snowing here
but, seems to be no spark.. So whats next chaps
ive actually already thought about that
blow it over the distributor???
Im serious by the way
Must be mad, fookin tonsilitus and outside in this weather, thats dedication
Sreriously tho, what should i do, cant see it being the dissy as i only replaced that for a new one before i went a way
i've tried mine today. theres a spark, but not a brilliant one. cleaned the contacts on the dissy to no avail. battery is now charging on mine as it was notably drained after numurous (sp) attempts to start it
annoying hey
Checked spark, no spark... but spark from coil is o.. so got to be either cap, arm or dissy
Been down halfords and as usual in stock
so gonna replace the car and arm, so if it helps
All CVH's (and Zetecs for that matter) are favourites for losing a lot of voltage thru bad leads. This always shows up in starting when cold/damp .. The old favourite for a CVH that was iffy to start in the cold/damp, was to change the cap/leads, and check the R Arm for tracking/burning.
Also, the amplifier can just fail "out of the blue" If you stressed it in some way, plus it got cold/wet, this also could have failed (about tenner from factors)
mines the same and has been since july of last year
was out in 3inch of snow last night trying to figure it out, may be your dizzy, as for the amplifier i thnik there ment to be on the dizzy but mine aint got one!!
good luck
so far i ahve checked
plugs
leads
coils
batteries
ecu;s
fule injection unit
and still fook all
good luck
plugs
leads
coils
batteries
ecu;s
fule injection unit
and still fook all
yeah no probs with the fuel at all
jsut dont wana go, i have been to it could be the sigma alarm but dont wana go hacking that up just yet
fookin thing,, now its a very expensive garden ornament and dog piss target.
Burning/cracking of the rotor arm means either coil overvoltage (which is unlikely) or arcing heat damage (like you get on the brush holders/commutators in the vacuum cleaner or power drill) Usually a poor contact prob, oil, or very high resistance in lead set (very wide plug gaps could even help cause it)
Most cases, just fit a new decent Rotor Arm mate
ahhh
was probably the oil then, the dizzy seal leaks a little bit so you get a ting bit of oil in the cap sometimes, but got new dizzy now but cant get the fooker to start
ta very muccle
ta very muccle
Got it started
Thought, fook it, change the plugs
it was the plugs
bit strange all 4 failing at the same time
But atleast it ya got it fixed and it's always worth changing the dizzy cap and rotor arm. and the fact that the rotor arm snapped when you removed it is dodgy
max
the reason it snapped is probably because of the way i removed it
but your right, worth changing anyway. I think it was flooded
So rather than clean the existing plugs, easier just to change them
I always assume the worst... bonus when its a cheap fix
Cheers for you help mate
So rather than clean the existing plugs, easier just to change them I always assume the worst... bonus when its a cheap fix
just a low comp 1600 mate
Plugs were replaced for the same ones that came out.. NGK's from Halfords.. handle 18psi fine
good luck in getting it running..
Right pain in the arse arent they, especially when you have no patience like me
Check fuel and immobiliser too
gonna bang some new plugs in tomorro and see how that goes
JoeyBoyden
Jan 4, 2024 02:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
