Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Metal cutting power tools
Old Jun 30, 2012 | 02:08 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default Metal cutting power tools
What other options are there for cutting up body panels and car metal work other than the good old angle grinder?
I find angle grinders far too imprecise and they have a wide cut and seem to need a fair bit of tidying up afterwards to get a neat edge.
Are there any neater powertools out there that can cut automotive panels leaving a fairly neat edge?
Old Jun 30, 2012 | 02:22 PM
E980VTJ's Avatar
E980VTJ
do you have a compressor? air saw's are good.
Old Jun 30, 2012 | 02:25 PM
Psycho Warren
Carbon Crazy
I dont have a compressor. No space for one really, although i was thinking of getting one of those small portable ones and sticking it in the shed when not used.
Anything run off the mains would be ok. Even nicer if a decent battery powered jobby existed. I borrowed a battery angle grinder once and it just didnt have the onions to cut through 2mm steel. Plus battery lasted so short a time to be almost useless. that was a few years ago though.
Old Jun 30, 2012 | 02:31 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
if you`re thinking a getting compressor what about a plasma cutter?
Old Jun 30, 2012 | 05:28 PM
Chaz888's Avatar
Chaz888
try a nibbler or slit cut disk's for your grinder
Old Jul 3, 2012 | 10:17 PM
langer's Avatar
langer
I use a dewalt cordless grinder and really thin discs (paper thin nearly) lol
Old Jul 4, 2012 | 01:24 PM
porterste's Avatar
porterste
Jigsaw with metal cutting blades
Old Jul 6, 2012 | 08:51 PM
Psycho Warren
Carbon Crazy
its a shame there arent any mini grinders same size as a dremel or similar.
Old Sep 23, 2012 | 09:15 AM
whizzisat114's Avatar
whizzisat114
ive got a recipricating saw from lidl or aldi it was Ł20 iirc and its cut a fair few things up form 4" wooden stumps to the rear turrets out of my car you can get different length blades for them from 4" long to about 8"
very versatile
Old Sep 23, 2012 | 06:05 PM
dingla rs's Avatar
dingla rs
you probly use the wrong discs the good ones are 1mm thick and very good ,a jigsaw with rite blade in is good for flat pannels ,aldi normaly have a few in
Old Sep 27, 2012 | 12:45 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
As said above get plasma cutting discs from machine mart for grinder, or if you aren't loaded get em off eBay for a tenth of price.
Or an electric nibbler, makes piss easy work of it, but won't cut up or downhill like the line around an arch, you can do whatever curves you want to cut but just not lips or panel creases etc.
Old Sep 28, 2012 | 02:29 AM
Psycho Warren
Carbon Crazy
its a shame you cant get a battery powered mini-grinder for scrap yard scavenging or work on tight spaces inside the car.
Old Sep 28, 2012 | 08:53 AM
dingla rs's Avatar
dingla rs
U can get battery powerd grinders we have one not much
Smaller than a 4 inch grinder tho
Old Sep 29, 2012 | 12:37 AM
Psycho Warren
Carbon Crazy
what would be cool is something dremel sized.
Old Sep 29, 2012 | 03:03 PM
AstoN_B's Avatar
AstoN_B
Air cutoff tools are quite small, as are electric nibblers.
Old Feb 11, 2013 | 06:33 PM
tosh's Avatar
tosh
I have used a Dremel for cutting out and patching bodywork, buy yourself a speed click adapter with some metal cutting 38mm disc's they are just like a miniature grinder disc and are very strong, I also use it with the flexy shaft for getting into tight spaces it cuts quick clean and with no over cut.
I have also seen this! but I think that the body and the guard would get in the way for cutting in tight areas
Look here: http://www.dremel-direct.com/acatalo...mpact_Saw.html
cossirob
Sep 16, 2015 07:39 PM
Si B
Sep 12, 2015 06:49 AM
Rizlablue
Sep 6, 2015 10:54 AM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
