Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Trolley jack won't lift high enough
Old Jun 26, 2012 | 12:57 PM
neilmcca's Avatar
neilmcca
Default Trolley jack won't lift high enough
Hello all,
I have a 2001 Mondeo,
I was going to change my brake pads and disc's earlier.
i used a trolley jack (brand new, although a cheap Aldi one) to raise the car, but even on it's maximum height, the wheel remained on the ground,
now i know it could be the trolley jack simply not lifting high enough, but i'm beginning to suspect something is broke.
i also used the standard jack which the car came equipped with , and even though that seemed to raise the car higher,
i still had the same problem, the wheel remained on the ground,
can anyone help !
Thanks,
Neil.
Old Jun 26, 2012 | 03:01 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
put a block of wood between the jack and the car or put a paving slab unde the jack.
ultimately the problem lies within it being a cheap jack.
Old Jun 26, 2012 | 04:35 PM
rd170's Avatar
rd170
Would have thought the standard one would do it. Have you lowered the car? Could be summit with the suspension, don't the likes of the big 4x4 have a strap round the springs for the same reason...
Old Jun 26, 2012 | 04:50 PM
neilmcca's Avatar
neilmcca
It hasn't been lowered,
was wondering if it could be a fault with the shock absorber !?
if i get the chance tomorrow, i will try the opposite side and rear of the car.
Thanks.
Old Jun 28, 2012 | 09:51 PM
studabear's Avatar
studabear
has the jack been bled as per the instructions?
Old Jun 29, 2012 | 01:25 PM
neilmcca's Avatar
neilmcca
err....no !
Old Jun 30, 2012 | 12:36 AM
zetecbeast's Avatar
zetecbeast
Under the car...!
Originally Posted by neilmcca
err....no !
The stock jack is mechanical anyway....right?!
That should lift the car high enough to allow a wheel change..
if it doesnt, and its at maximum extension, there could be something amiss!
Old Jun 30, 2012 | 06:07 AM
AJC's Avatar
AJC
Definitely lifting on a good point and not the passenger floor pan? As that'll just sink in and push the floor up
Old Jun 30, 2012 | 06:15 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
you have to laugh at the std scissor type jack you get with cars they are all a joke and fookin dangerous
what a feet of modern engineering
Old Sep 27, 2012 | 01:24 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Lol seen that a fair few times!
Old Oct 1, 2012 | 11:37 AM
Brendan's Avatar
Brendan
struggling with reality
use the manufacturer supplied to see if you can lift up the car to do the job, but do not trust it! see if you can borrow or get an axle stand.
Old Oct 2, 2012 | 04:28 PM
MrJayware's Avatar
MrJayware
You can get a Ł20 trolley jack from tool station and that lifted a freelander off the floor to do pads and is was sitting on 18" wheels. Get a proper one not a cheap one
Old Oct 2, 2012 | 09:14 PM
cossie.con's Avatar
cossie.con
May be the jack is short of oil=ing faulty item(take it back)
Mik
Old Nov 5, 2012 | 09:29 AM
alton97's Avatar
alton97
Nice post. I like it. Thanks for sharing these information. Keep it up.
Old Nov 5, 2012 | 09:40 AM
rog's Avatar
rog
Hopefully almost 6 months later he has fixed it, nice attempt at getting your post count up though.
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
