ST170 Sump Replacement
Old Jun 18, 2012 | 08:39 PM
stevetracey's Avatar
stevetracey
Default ST170 Sump Replacement
Hi,
I am planning to replace the heavily rusted sump on my ST170. This seems like a common issue reading the posts on here.
The bolts on the cat also look badly corroded - will probably need cutting / drilling out.
The question I had - are these bolts "captive" / part of the downpipe / cat, or can I replace these? The cat looks in good shape, so reluctant to replace the whole thing.
Can I get away with just dropping the cat from the downpipe, or do I need to actually remove it?
Thanks in advance for your help.
Steve
Old Jun 18, 2012 | 09:25 PM
Sp3no's Avatar
Sp3no
The sump bolts are not captive and even i they were its no problem to cut off the nut or drill out the thread and fit a normal nut and bolt. When i took the cat off mine it sheared off the bolts and replaced with new. A new CAT from ford will set you back Ł600+ a cheap cat replacment will lose you power, keep the standard one if you can as they are very efficient
Old Jul 3, 2012 | 06:14 PM
stevetracey
Thanks very much for the info!
Do you think I need to completely remove the cat, or just lower it from the exhaust downpipe end?
Cheers,
Steve
Old Jul 3, 2012 | 08:35 PM
stevetracey
....Also the bolts are so rusted I can't quite see what size they are - guessing around M14x35mm?
Any ideas?
krypton
Sep 23, 2015 07:29 PM
Vacuman
Sep 22, 2015 12:09 PM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
