Remapping Q?
Old Jun 11, 2012 | 02:58 PM
smokey's Avatar
smokey
Default Remapping Q?
Recently, the exhaust on my Zafira GSI was rotting away, so I had it replaced with a Milltek job and had it remapped at the same time at AMD in Essex.
Due to a slight crack in the manifold, the full potential was no realised so I enquired about fitting a later Zafira VXR turbo and manifold on.
I also asked about remapping after fitting and was told that "The map that is on your car will adapt to the new Turbo so will not need to be adjusted."
Just wondering wether this is plausible, that a map will adapt to any changes?
Thanks
Old Jun 11, 2012 | 03:02 PM
E980VTJ's Avatar
E980VTJ
remember on vectra-c that people used to say that the ecu learns your driving style,I always thought it was BS but maybe true
Old Jun 11, 2012 | 03:21 PM
pani_k's Avatar
pani_k
PassionFORD Member
Could well work however I don't think it would work very well, I've never heard of a map that can suit 2 turbochargers, best guess flash maps especially.
Old Jun 12, 2012 | 10:34 AM
Jim Galbally's Avatar
Jim Galbally
whilst i dont know for sure i very much doubt it will adapt as you will be modifying the engine's VE!
Old Jun 12, 2012 | 05:37 PM
foreigneRS's Avatar
foreigneRS
Testing the future
maybe it has an air mass flow sensor to work off and make some adaption, but certainly won't be optimised and could be dangerous
Old Jun 12, 2012 | 06:27 PM
martysmartie's Avatar
martysmartie
Correct, nothing special, it's true of any example of 'adaptive' engine management, hence the name, it's not your driving style though, rather different conditions, as in the case of the former it will reference the map relevant to the drivers input.
Re the OP's question it depends tbh, as with any computer the ECU can only do what it has been told, i.e. mapped for, so if the turbo is different then I would say it would need remapping imo.
Martin
Old Jun 13, 2012 | 09:59 AM
smokey's Avatar
smokey
Thanks lads. Have to think about this one carefully.
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Nov 1, 2015 06:53 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Sp3no
Sep 27, 2015 07:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
