Wastegate.
Old May 28, 2012 | 04:22 PM
mgsdetail's Avatar
mgsdetail
Default Wastegate.
Would the wastegate being open abit all the time cause the thrust bearing to wear with a 1k of a new build running low psi (11)???
Old May 28, 2012 | 05:38 PM
GUZZLER's Avatar
GUZZLER
It could do, excessive thrust wear is normally caused by too much boost, a leaking/partially open wastegate would cause the turbo to overspeed, this can damage the impellers but will also put excessive wear on things.
If the turbo has been rebuilt by a proper company then they often set the actuator when the unit is reassembled.
If your not happy then send it to Turbosystems, Tony will get it sorted for you at a fair price.
Old May 29, 2012 | 08:39 AM
Stu @ M Developments's Avatar
PassionFords Creator
No, the wastegate being permanently open will limit turbo speed and acceleration and thus slow down potential wear.
Old May 29, 2012 | 08:40 AM
I suspect your thinking about a leaking wastegate "Actuator" Matt.
Old May 29, 2012 | 08:46 AM
RickyLee53's Avatar
RickyLee53
As above, wastegate been open would just make the car slow. Wastegate closed could cause damage.
GUZZLER's Avatar
GUZZLER
Stu, if the wastegate is stuck open then the turbo will overwork as its trying to create a pressure but most of the air it flows go's straight down the exhaust, hence the turbo will have to do more work to try to generate the same pressure.
A leaking actuator would keep the wastegate shut causing over boost.
Old May 29, 2012 | 10:24 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
no it wouldn't Guzzler
Stu is right you are wrong
Old May 29, 2012 | 10:28 AM
scoooby slayer's Avatar
scoooby slayer
it wont fella because the gas will be bypassing the exhaust wheel instead of spinning it.
Old May 29, 2012 | 10:29 AM
It wouldnt mate. A turbochargers workrate is directly related to the air flow through its turbine wheel, so if you limit this airflow, you limit the work done, and that is the sole reason for the wastegates existance, to limit flow and thus work. It truly is as simple as that.
Old May 29, 2012 | 07:10 PM
GUZZLER's Avatar
GUZZLER
For some reason I was thinking of a leak on the compressor end..... Been bad times for me of late, but I'll take the 'nob 'ed award
Old May 29, 2012 | 07:20 PM
mgsdetail's Avatar
mgsdetail
Thanks for all your relpys guys. It seems that I might of been lied to by my rebuilder for warranty work.
Looks like when I get it back I should send it to Tony at Turbosystems as after reading a few post about him, he seems honest and very fair.
Thanks Mark.
Old May 29, 2012 | 08:06 PM
scoooby slayer
Thanks Mark.
it does look that way fella, its not an acceptable diagnosis.
May 31, 2016 09:28 PM
AJC
Feb 16, 2013 05:23 PM
Kelv
Jun 21, 2007 07:18 PM
