Wastegate.
It could do, excessive thrust wear is normally caused by too much boost, a leaking/partially open wastegate would cause the turbo to overspeed, this can damage the impellers but will also put excessive wear on things.
If the turbo has been rebuilt by a proper company then they often set the actuator when the unit is reassembled.
If your not happy then send it to Turbosystems, Tony will get it sorted for you at a fair price.
Stu, if the wastegate is stuck open then the turbo will overwork as its trying to create a pressure but most of the air it flows go's straight down the exhaust, hence the turbo will have to do more work to try to generate the same pressure.
A leaking actuator would keep the wastegate shut causing over boost.
It wouldnt mate. A turbochargers workrate is directly related to the air flow through its turbine wheel, so if you limit this airflow, you limit the work done, and that is the sole reason for the wastegates existance, to limit flow and thus work. It truly is as simple as that.
Thanks for all your relpys guys. It seems that I might of been lied to by my rebuilder for warranty work.
Looks like when I get it back I should send it to Tony at Turbosystems as after reading a few post about him, he seems honest and very fair.
Thanks Mark.
Thanks Mark.
AJC
16-02-2013 05:23 PM
