Clocks fail and won't start
Old May 25, 2012 | 08:15 AM
wag_7's Avatar
wag_7
Default Clocks fail and won't start
Hi all,
Yesterday evening i was driving home in my st170 and the clocks radio just failed on the me. The heater then blew intermittently. Once i got home and parked up i turned the engine off, waited a few mins and then turned the key to bring up the dash lights. all came back on but when i tried to start the engine didn't turn and all i got was clicking.
I left the car for an hour or so and when i went back to it it started ok. I took it for a short drive to test it and the same thing happened. The dials failed again. I asked at the local garage and they said it needed new clocks?
I have done some research and have heard you can clean one of the circuits and waterproof it with wd40 but i am unsure if this is the problem?
Can anyone help me?
Thanks
Old May 25, 2012 | 01:11 PM
wag_7's Avatar
wag_7
Further to the last post i have tried to start the car and the battery was completely dead. Could this be an alternator problem?
Old May 25, 2012 | 02:04 PM
E980VTJ's Avatar
E980VTJ
if you can get it running check the volts at the battery should be over 14v,any fault codes?
Old Jun 3, 2012 | 08:03 PM
minder's Avatar
minder
if all your lights are playing up while your driving and was dead the following morning then i would say you def need a new alternator as its not holding the charge in the battery
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
Bailes1992
Sep 3, 2015 02:17 PM
kevin36
Sep 2, 2015 06:24 PM
Sultzi
12
Aug 16, 2015 01:08 PM
