Problem with distributor / ignition
Old May 15, 2012 | 09:59 AM
Cyril Sneer's Avatar
Cyril Sneer
Default Problem with distributor / ignition
Hey guys,
actually I have a problem installing the distributor on my cosworth engine.
When I first installed it like it is told in the Cosworth manual, I wasn't able to start the engine.
I tried to fire it up and when the engine stops, it turned for a second in the wrong direction.
This is usually a sign that there is a problem with the ignition.
So I tried to turn the distributor clockwise and it went better and better.
But in my opinion, there is something wrong.
I took some pics of my installation:
Crank wheel/ 1. cylinder is TDC
Cam wheels are pointing together
firing order is clockwise 1-3-4-2
As you can see, the rotor doesn't align with the marking on the housing...
BUT... the idle speed is good and also the acceleration...
I am running a P8 Ecu with a program which i don't know and yellow Bosch injectors.
I guess the engine has about 280 hp...
What is your opinion? Please help...
Thanx alot...
Sneer
Old May 15, 2012 | 10:43 AM
Cyril Sneer
@mod
please delete thread, I moved this to another forum.
THANX!
Old May 15, 2012 | 10:50 AM
rog's Avatar
rog
When you installed the distributor, did you line up the marks, then move if afterwards, is that what you're saying? I'm not 100% certain on youre issue, but what you have shown regarding the distributor is NOT right, it needs to be aligned.
Old May 15, 2012 | 11:14 AM
Cyril Sneer
That's what I mean rog, when I allign it to the mark, it is impossible to run the engine.
Only like the above pic, when the rotor is before the marking, the engine runs good...
That's my strange problem....
Daniel Howard
17
Sep 26, 2015 12:39 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
dms04
Sep 11, 2015 01:57 PM
