Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Fitting car seat in rear of ST3
Old May 4, 2012 | 08:23 AM
JK12's Avatar
JK12
Default Fitting car seat in rear of ST3
Hi,
Gota get my daughter her next car seat which will fit in the back, with the ST3 do i need to get the iso fix bar fitted from fords to enable the seats to fit?
Or is it ok to strap the seat in as normal? Women at mother care wasnt very helpful so thought i would ask on here what others have done?
Cheers Jamie
Old May 4, 2012 | 08:25 AM
.Ross.'s Avatar
.Ross.
Not come Ifixo's as standard mate?
Check the seat instructions for fitment. Don't use both.
If not then get the bar thingy ... Defo the way forward
Old May 4, 2012 | 08:29 AM
JK12's Avatar
JK12
No not standard at all, ford wants Ł70 for this bar, but not sure i even need it really?
Old May 4, 2012 | 08:32 AM
.Ross.'s Avatar
.Ross.
Have you already bought the seat? Guess not.
If you buy a proper seat like a Britax it will be Ifixo ready.
If you wanna go seat belt secure then make sure the seat is compatible.
If you buy the bar, have Ford fit it mate. Don't cheap out unless it's a 10 second job.
Old May 4, 2012 | 08:45 AM
JK12's Avatar
JK12
Yes going to dummy fit the seat at MC later, just hope this women aint there again lol
Would 100% get ford to fit, my little girl comes before Ł
Thanks for help by the way mate
JK
Old May 4, 2012 | 08:49 AM
dojj's Avatar
dojj
Resident Wrestling Legend
When I was enquiring about isofix for the Mondeo they said they had to slit the leather toget to the fixing so I bought a different seat
Old May 4, 2012 | 08:58 AM
.Ross.'s Avatar
.Ross.
No problem Jk. Hope the bar just bolts in without any bullshit.
Fuck me Dojj. My 08 had 4 sets of fixo's.
So much for European standard's
Old May 4, 2012 | 09:08 AM
dojj's Avatar
dojj
Belted seats should be fine, why you need to anchor them to the seats is beyond me
Unless some folk simply don't understand how to belt up their kids safely I suppose
Old May 4, 2012 | 09:14 AM
.Ross.'s Avatar
.Ross.
Cheap out on the child's safety and buy some decent brake pads instead.
Old May 4, 2012 | 10:06 AM
dojj's Avatar
dojj
My kids have been fine in the belted child seats we bought for them years and years ago, and have never had any issues with them
Fit and forget
If you are talking about the little rear facing seats then I can see the argument as they are a lot more fiddly to fit in and out of the car and some cars we tried to fit our original car seat into didn't have enough seat belt length to actually go around
Old May 4, 2012 | 11:22 AM
bookwyse's Avatar
bookwyse
Remember though that the ST3 has a diffrent bench seat and not all car seats will fit due to this.
We had difficulty finding one to fit when we got the wifes ST3
Old May 4, 2012 | 02:01 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
i had real issues getting the front seats forward enough to get a car seat in and out on my old 3dr ST2 and the seat belt was only just long enough!!!
Old May 4, 2012 | 07:02 PM
RichieST's Avatar
RichieST
I've got a car seat base permanently strapped into my 5 dr st2. Car seat just clips in and out of that.
Old May 6, 2012 | 09:34 PM
cossiecol83's Avatar
cossiecol83
Thats part of it!!!!
I've got a ST2 and have a little girl too and her seat is in with isofix and just had it fitted to the other side as I've got a another little girl on the way. It's the best way to have the car seat. I got both mine done at ford, it's so much better then useing the belt. 😃
Old May 6, 2012 | 09:47 PM
Carlos-Titx's Avatar
Carlos-Titx
Only problem using a car seat in the st3 Is the seat belts are a bit short in the back and no option to turn the passenger air bag off if you want the seat in the front.
Have my niece in the back of mine a fair bit, luckily the seat base is narrow so fits in the rear seat perfect. But the belt is very short and need to tilt the baby seat a little to fit the belt correctly just for an extra inch.
Old May 6, 2012 | 09:49 PM
RichieST's Avatar
RichieST
You can get a key switch to turn the passenger airbag off as an option Carlos.
Old May 6, 2012 | 10:00 PM
JayCC's Avatar
JayCC
You can have this retro fitted, but for the fiesta st, it's like 100-140 quid! Fucking insane!
Old May 6, 2012 | 10:31 PM
Carlos-Titx
How do I go about that Rich? Can I get it now or was it an option at new?
Old May 7, 2012 | 08:30 AM
RichieST's Avatar
RichieST
yes you can have it done as a retro fit, the key switch goes in a blank next to the esp and heated seat switches or in the glove box next to the aux socket. Have a look on the stoc, remember seeing a thread on there. Will copy it over for other members to see when I'm on the computer.
Old May 7, 2012 | 09:23 AM
RichieST's Avatar
RichieST
Here's the switch
And the thread
THIS IS A DEALER FIT OPTION PLEASE DO NOT CONNECT ANY SWITCHES YOUR SELF ONLY FIND THE WIREING
GUIDE:
HOW TO FIT FACTORY AIR BAG DEACTIVATION
b]PRICE TO FIT:[/b] Ł38 Parts, Ł20 Ford for Programming
PART FINNIS NO REQUIRED:
1381035 key switch
1035250 sticker Decal
1353959 Blank Switch Light
DO NOT CONNECT ANY SWITCHES JUST PULL THE WIRE OUT THOUGH THE HOLES ELSE THE AIRBAGS WILL GO OFF!!!
step 1:
remove the glove box
Step 2:
Find the wire taped up at the back
Step 3
Remove the Knock out Pannel next to the MP3 Socket
Step 4
then Pull the wire though
Step 5
Refit the glove Box leaving the wire out (i taped mine out wire masking tape so it would not go back in)
Step 6
Find 2 Small Flat Headed Screw Drivers and cover them with masking tape so they will not scratch any pannels
Step 7
insert then screw drivers into the pannel gaps near the blank (as shown in red) and then push the screw drivers outwards to pop the blank out.(the pic shows the light blank fitted)
Step 8:
On the back of the blank theres a wire pluged into it. this is just to store the wire so you can remove it from the black and again masking tape it down so its ready to have the new blank (as shown in the pic above) fitted.
Step 9:
Open the Passanger Door And remove the Sticker that shows and states NO CHILD SEAT IN FRONT and replace with new Decal.
Step 10:
Take all parts to ford and ask them to program with the WDS laptop (it should be Ł20 as its a small 10 min program) And Fit the Switches
ONCE AGAIN DO NOT CONNECT ANY SWITCHES GET FORD TO PROGRAM AND FIT THEM TO YOUR CAR!
Old May 7, 2012 | 09:45 AM
Carlos-Titx
Nice one. Thanks for that Richie
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
Graceland
Jul 31, 2015 10:34 AM
