Gearbox :/
Old Apr 17, 2012 | 05:20 PM
daniel buckley's Avatar
daniel buckley
Default Gearbox :/
Some clever person has sold me a xr4x4 gearbox and told me its a cosworth box 4x4 so all fitted today and then built all up to go and fix the clutch on to find the arm is to short so made a phone call and someone I called confirmed this was correct instead of fitting it all over again and swapping arms just wondering if I fit a xr4x4 clutch cable would this work any help would be a great help thanks
Old Apr 17, 2012 | 06:10 PM
Gary F's Avatar
Gary F
It has a different bell housing, look at the top bolt holes compared to your old box.
Old Apr 17, 2012 | 06:13 PM
saph4be's Avatar
saph4be
Is starter motor in different place too?
Old Apr 17, 2012 | 06:19 PM
Gary F's Avatar
Gary F
I think it is, but can't remember.
Old Apr 17, 2012 | 06:20 PM
Gary F's Avatar
Gary F
You could just stick all of the XR's gearbox internals into your casing I'm sure.
Old Apr 17, 2012 | 06:22 PM
daniel buckley
Fits identical everything is on just not enough slack in clutch cable to release the clutch
Old Apr 17, 2012 | 07:31 PM
Marc sierra's Avatar
Marc sierra
Then the box is from a 2.0 DOHC XR4x4. I think the input shaft, ratios and bearings are different from the cossie box. The V6 XR4x4 box also has a different input shaft, but the same ratios and bearings as the cossie box. But on the V6 box the bell housing is different from the 4 cilinder boxes.
So there's not much you can use from the 2.0 XR4x4 box I'm afraid.
Old Apr 17, 2012 | 07:46 PM
daniel buckley
Box is on mint everything same but there's no give in clutch cable at all I can hook it on but it keeps the clutch on and won't release
Old Apr 17, 2012 | 08:04 PM
pee vee's Avatar
pee vee
you have released the cable from the adjuster/ratchet on top of the clutch pedal, right??
cant remember how you do it on a cossies now though lol
Old Apr 18, 2012 | 08:19 PM
daniel buckley
Cheers for that all sorted now thanks
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
