Mk4 escort zetec turbo!
Old Apr 17, 2012 | 03:30 PM
Escortrs2000's Avatar
Escortrs2000
Smile Mk4 escort zetec turbo!
Hello iv got a mk4 escort rs turbo rolling shell, and im thinking off doing a zetec turbo conversion, could anyone give me a list off everything i will need, and what management i will have to run? Cheers.
Old Apr 18, 2012 | 08:53 AM
HirenRS's Avatar
HirenRS
turbovh
engine
fiesta turbo inlet manifold
adaptor plates
exhaust
frs management
t3 exhaust
...i got azvh if u intrested complete thing and a t3 exuast
Old Apr 18, 2012 | 09:19 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Depends hugely on what power you're after, as well as budget.
Old Apr 18, 2012 | 10:34 AM
Escortrs2000
Not after huge amounts off power about 180bhp? Iv heard if i run it on low boost i can run it on standard management?
Old Apr 18, 2012 | 11:07 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Easily done without even opening it up.
Escort T3 and manifold
FRS inlet can be had cheap these days and are much better than the shitty HO inlets.
Cheapo cooler off eGay
I can't remember if the injectors need changing though
I spoke to Neil at FastFord about it, he's your man for cheap ZT conversions.
The standard ecu can be mapped, I'd run 8 psi which will quite happily see you with more like 220-230bhp.
Old Apr 18, 2012 | 11:08 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Don't forget some ARPs, and valve springs wouldn't go a miss for the price, although not essential.
Old Apr 18, 2012 | 12:14 PM
Escortrs2000
Iv also heard that i can run puma injectors? How do i speak to neil at fast ford? Cheers.
Old Apr 18, 2012 | 05:04 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Totally contradicted myself when I said ARPs as that requires opening it up haha.
Never heard of anyone using Puma injectors mate, possibly Focus RS injectors IIRC.
He's on here as Neil@fastford.
Old Apr 18, 2012 | 07:25 PM
Escortrs2000
Ok cheers mate il see what hes got to say
Old Apr 19, 2012 | 07:45 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
If you do a search, I made a thread a while back about cheapo ZTs, search "budget Zetec turbo" IIRC.
Old Apr 19, 2012 | 07:50 AM
zippyobrien's Avatar
zippyobrien
Almost all of what you gave just told this fella is false mate.
Do a search. Plenty of info on here about conversion. And standard zetec management won't run it.
Old Apr 19, 2012 | 08:03 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
You better tell Neil that his MK1 Fiesta won't work then
And you better have a read up of this thread. https://passionford.com/forum/genera...the-cheap.html
Old Apr 19, 2012 | 08:50 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
FRS inlet better than the HO one, i'd like to see the flow map then, can't see how that is possible.
the rest of the info is fairly accurate, injectors wouldneed changing as would management to map for positive pressure, probably OFAB from the FRST, only issue there is the TPS, but you could use a cvh efi inlet on an adaptor instead. for you power target it will be more than adequate, even though not 100% ideal.
Old Apr 19, 2012 | 10:11 AM
zippyobrien
How are you going to lower the compression ratio with out opening the engine up ?
A focus Rs inlet is the same as any 2.0 black top inlet, only tb and injectors are different.
8 psi will not see 220 bhp for shit. Be surprised if you see 175 bhp especially if on ofab with a shity eBay cooler.
The only bit you said which was useful is the escort t3 part.
Best way IMO is either,
Vag 20v pistons in a 1.8 black top.
Or st170 bottom end with 2.0black top head.
Any thing else is just a ticking time bomb ( decomp plate, skimmed pistons )
Even with the above set up you'd probably end up running fiesta Rs management which is FAR from ideal.
Try not to cone on here telling people it's cheap easy to do, because it's not.
I reckon budget atleast Ł1000 for the most very basic crappy zetec turbo build.
Old Apr 19, 2012 | 01:31 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it's funny you quote a grand, as just a few days ago i totted up a basic zetec turbo setup for about that without mapping/management.
8psi can easily get 200bhp+ on a 2046cc engine, but it is turbo and spec dependant on the rest of the kit. there are plenty of ZT's that hit over 300bhp on a BAR.
Old Apr 19, 2012 | 04:04 PM
zippyobrien
Indeed it will with a decent turbo ( not a shite escort t3 ) and a 2046cc isn't a unopened engine as quoted by crowson.
On a standard lump with a decomp and ofab with a chip 10psi is about 200bhp. But will blow up , just depends how long and how lucky you are.
Spend a grand. Decent coast t3 or a t28 of a 200sx. ( or even better a standard focus Rs manifold and turbo) and megasquirt on a decent lump will see a nice reliable 220 bhp all day long. But will cost 2k minimum by the time you've bought a fuel pump, intercooler, few bits of pipe , the engine and management.
Old Apr 19, 2012 | 08:54 PM
Escortrs2000
I know someon with a zetec turbo at 280 brake with a de com plate and different rod bolts the only thing im struggling on is cheap management?
Old Apr 19, 2012 | 09:05 PM
gjh's Avatar
gjh
Does a focus RS head gasket work for zetec turbos? Its thicker than the usual zetec engine ain't it, and maybe help lower the compression ratio? Or am I wrong here?
I ain't seen Neil on here in ages, where is the guy?
Billy_RS
16
Oct 11, 2025 09:41 PM
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
turbobill
Aug 9, 2015 05:21 PM
