launch control on megasquirt
Old Apr 8, 2012 | 05:40 PM
project rs's Avatar
project rs
Default launch control on megasquirt
have any of you guys running megasquirt tried it and if so could you post a screen shot of your settings if poss to speed up the process for me if not i'll do the trial and error route
Old Apr 8, 2012 | 09:47 PM
Rob_DOHC's Avatar
Rob_DOHC
Here you go mate,
Still haven't found a base map that would be any good for yours but i do have some launch settings
Other setups i have seen run a low as 1deg advance and have a lower rev limit. I found this worked well but was very harsh, so backed it off to 3deg and have a slightly higher rev limit due to the sticky tyres i was running. On normal road tyres i would go for a lower rev limit, or retard the timing less, or pull fewer sparks. This will limit the boost made on launch but also help with traction.
Launch control is good fun
Rob,
Old Apr 8, 2012 | 09:48 PM
Rob_DOHC's Avatar
Rob_DOHC
My Input/on value may be different to yours too depending upon which input you are using for launch.
Happy pops and bangs
Rob,
Old Apr 8, 2012 | 10:10 PM
project rs's Avatar
project rs
cheers rob and yes your right my input is js4 but gives me some values to start with, think my neighbours are going to love me this week while i set this my nos and antilag just hope they look at it and think what an old banger won't even run right it's backfiring like mad
Old Apr 9, 2012 | 03:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I would set the TPS threshold higher then 20% otherwise if you accidentaly rest your foot on the clutch at high RPM it will engage when you dont want it to, mines at 90% for example.
Old Apr 9, 2012 | 07:37 PM
project rs's Avatar
project rs
thanks for the advice, hows the zt coming on
Old Apr 10, 2012 | 07:33 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah all good! Running about a 14psi at the moment (dont think the .48/60 will flow much more TBH), feels about as quick as my CVH did at 30psi (around 270bhp) but have literally only spent 45mins mapping to just make sure it's safe!
Much more responsive and so much quieter than the CVH too, engine itself that is not the exhuast note as that sounds exactly as it did before!
Old Apr 10, 2012 | 07:49 PM
studabear's Avatar
studabear
Sounds good karlos, cvh's do sound cack hahahahahaha
Old Apr 10, 2012 | 07:50 PM
Rob_DOHC's Avatar
Rob_DOHC
Sweeet sounds like its all going well Karlos! Have a play with the TPS value Rick, I kept it quite low as you can use the throttle to adjust severity, with the throttle backed off mine was making 5psi boost, planted it made over 10 but it did sound very violent lol!
Rob,
Old Apr 10, 2012 | 07:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Only thing I dont like is it doesnt pop/bang when launching or flat shifting like the CVH did, I get the odd one but nothing like it used to! lol
Not had a chance to play with the settings yet though!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
markk
Sep 9, 2015 08:11 AM
