S2 running problem
Old Apr 5, 2012 | 07:16 PM
Ryoishikawa's Avatar
Ryoishikawa
Default S2 running problem
It holds back around 4k revs when driving
Things I've changed
oil pump
water pump
Fuel filter
Spark plugs
Oil
Ht leads
Rotor arm
Dizzy cap
Coil
Boost hoses
Radiator
Did change actuator to -31 but boost came on late
Checked for air leaks
I'm still new to s2/ turbo cars
Is this normal
Old Apr 5, 2012 | 08:16 PM
paul-h's Avatar
paul-h
What boost pressure you running? Ecu chipped?
Old Apr 5, 2012 | 08:21 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Either its not chipped or its doing what mine used to and retarding itself. Mine turned out to be a dodgy ecu so I used a s1 ecu that gets rid of the knock sensor that was the problem with mine anyway. I'd take it to a reputable tuner and get it set up. The one I used found my fault streight away. Hope this helps a little. Nick.
Old Apr 5, 2012 | 08:34 PM
Ryoishikawa
It's not chipped I'm running 7psi
Old Apr 5, 2012 | 08:51 PM
paul-h's Avatar
paul-h
I take it you have a boost gauge?
As suggested, take it to a tuner and let them set it up properly!
Old Apr 5, 2012 | 09:00 PM
beaver rs 88
in the garage
Does it feel as though the boost is been cut or it just not boosting if your running a 31 actuator and its not chipped I'd say that's a problem to start. Try the standard actuator mate if your not chipping it.
Old Apr 6, 2012 | 06:14 AM
paul-h's Avatar
paul-h
I may be wrong but it seems to me like he went back to a standard actuator as the -31 made it laggy?
Old Apr 6, 2012 | 07:47 AM
Jeesy's Avatar
Jeesy
Jeesy
Mine S2 has a -31, no chip (as I know ), boost 0,7 bar and everything works fine..
Have you tried different adjustments with the actuator rod?
Old Apr 6, 2012 | 05:54 PM
bigkev's Avatar
bigkev
when i had rs turbo engine , mines done exactly the same, it was the fuel metre, wen i disconnected the plug on the fuel meter it stopped tht problem, so got new meter and job done
Old Apr 6, 2012 | 06:49 PM
Ryoishikawa
Went back to the standard actuator as it was bad . Even went back to the k.n cone still the same.
My old actuator is worn so bad
Jeesy you got a picture of ur actuator on the rod side
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
