Primer
Old Feb 26, 2005 | 07:05 PM
Adz 131's Avatar
Adz 131
Default Primer
Hi all just a quick question What's the best primer to use for doing the underside and engine bay of a saph? I no about Acid Etch primer and zinc primers and was wondering if there is anyother primers you lot can think of or have used and had good results?
And what would be a good high build primer to put on top of the above?
Old Feb 26, 2005 | 10:52 PM
Adz 131's Avatar
Adz 131
Default Primer
Sorry all forgot to ask
How many coat's of primer should i put on
And how many coat's of seam sealer / stonechip should be applied?
Old Feb 27, 2005 | 10:13 PM
Adz 131's Avatar
Adz 131
Default Primer
Come on Give me some info please????
Old Feb 28, 2005 | 11:00 AM
McCloud 85's Avatar
McCloud 85
If you are going to spray paint the underside using a paint such a 2 pack then you will need to use a compatable primer, i do not know as i use cellulose, however for that just use a normal cellulose primer or aerosol grey primer.
if you have prepped the surface well berfore applying the primer, there is no reason why you wont get a good result with either one.
hope this helps.
Wilsfoci
15
Mar 30, 2016 10:26 PM
Paul_RS
Jan 3, 2006 12:08 PM
RSBen
Jun 19, 2005 07:52 PM
Neil S
20
Apr 6, 2005 07:42 PM
666monkey
Jun 2, 2004 04:48 PM
