Boost gauge help!
Old Mar 23, 2012 | 08:04 PM
Ryoishikawa's Avatar
Ryoishikawa
Default Boost gauge help!
My boost gauge from racetec is reading -0.5 bar and when I rev it when the car is hot goes to 0 bar
I've checked the turbo
Replace the oil feed
New -31 Garrett actuator
checked intercooler for cracks and replaced the hoses too
Checked intercooler pipes for leaks all good
What am I missing or is this normal
Old Mar 23, 2012 | 08:37 PM
Sjieter's Avatar
Sjieter
you do realise you have to drive the car to get it to read the set boost?
-0.5 at stationairy is perfectly normal, and yes 0 bar when revving is also normal.
When going out and driving the car you WILL see the boost rising..
Old Mar 23, 2012 | 08:39 PM
Ryoishikawa
Oh I'm new to this . Thanks
Old Mar 23, 2012 | 08:45 PM
Sjieter's Avatar
Sjieter
did you still have the original rs turbo actuator before the -31 actuator? if thats the case what pressure are you running it on now then?
Old Mar 23, 2012 | 08:50 PM
Ryoishikawa
I've still got the standard part . Replaced it for the -31 will test it when I drive the car on Ramps now
Old Mar 23, 2012 | 08:53 PM
Sjieter's Avatar
Sjieter
i'm pretty sure you will be running some high boost , so please don't go all out.
See what boost it reaches , if higher than 0.55 bar ( assuming it is standard ! ) then make the rod of the actuator longer until you have your boost right.
I've put my original rs turbo actuator back on as i'm running 0.6 bar and its a pain in the ass to get 0.6 bar with a -31 actuator it will always end up with 0.7 bar.
Just so you know
Old Mar 23, 2012 | 09:11 PM
Ryoishikawa
I have a large intercooler from air tec was hoping for about 10 psi
Old Mar 23, 2012 | 09:13 PM
Sjieter's Avatar
Sjieter
you still have to get it setup for that amount of boost, best is to go back to standard boost pressure and when you get it setup than go for the boost you want.
Old Mar 23, 2012 | 10:17 PM
martysmartie's Avatar
martysmartie
Yes as you have absolute pressure, with the throttle closed you have vacuum (hence the -reading) only under load will you achieve positive pressure, aka boost.
As said you can't simply just adjust the boost, unless you plan on destroying your engine, you need to run the set amount of boost it's setup for.
Martin
Old Mar 23, 2012 | 11:04 PM
mgtkr1's Avatar
mgtkr1
i set mine at 12 ish psi but refrained from going all out for any length of time as i knew i would be getting the fuelling setup. you MUST get your fuelling setup when you raise the boost pressure. your tuner will advise what is a safe amount and should set the fuelling to match the desired boost level so that is a/f is at a safe level. lean at wot means melted pistons. best just stick to the 6-7psi until the day before your rolling road session and drive off boost to the tuner.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
