Cars on the road with a few niggely issues can anyone help?
Old Mar 16, 2012 | 07:31 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Cars on the road with a few niggely issues can anyone help?
Hi guys cars finally on the road and have one or 2 issues im hoping you can help with, bare in mind bay has been completely stripped and then put back in
No indicators/clicking too fast.....im pretty sure this will be a bad earth
No rev counter lights at all.....possibly same earth?
And when you go to lock the car, it locks then unlocks again, but the car did this before, its the same weather you use the fob or key.....maybe central locking motor?
Just wondered if anyones tackled these before and could give me an answer before i go fault finding tomorrow
Old Mar 16, 2012 | 07:47 PM
Fordmad!'s Avatar
Fordmad!
Indicators, is it both sides or just the one?
Old Mar 16, 2012 | 08:00 PM
Adam.'s Avatar
Adam.
Both mate, it did start doing it before the engine came out.......Stalk relay maybe?
Old Mar 17, 2012 | 08:31 AM
Fordmad!'s Avatar
Fordmad!
Usually get this on my escort van and its a dodgy connection to the lights (wire or plug not on properly)
Id check connection to the stalk aswell though and the earths especially if you've had it sprayed. Spray some contact spray on the connections.
Rev counter could be linked so would suggest an earth problem or connection behind dash somewhere
As for locking, mine does this when one door isnt shut properly so make sure you doors shut flush and straight
Old Mar 18, 2012 | 08:54 AM
Adam.'s Avatar
Adam.
Fixed the indicators and brake lights, was a relay and a fuse
Fixed the rev counter wasnt pushed in far enough,
Going to look at the doors today
Old Mar 18, 2012 | 09:11 AM
fraser9764's Avatar
fraser9764
My van does similar with the locks when the linkage from the actuator to the lock mechanism gets a bit tight on the front doors. Just take the door cards off, lubricate and exercise
Old Mar 18, 2012 | 10:00 AM
vaughant's Avatar
vaughant
Yeah,I'd go for a stiff door lock etc,won't be anything too major!!!
Old Mar 18, 2012 | 10:05 AM
robby421's Avatar
robby421
could be door shut pin not workinan wont lock as thinks a door is unlocked mate possibly
Old Mar 18, 2012 | 03:14 PM
Adam.'s Avatar
Adam.
we have messed with the door catches as its had new 1/4 panels, doors have been off etc, so thanks lads will try your suggestions
JoeyBoyden
Jan 4, 2024 02:36 PM
yawiejon
15
Aug 9, 2015 06:36 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
