Ordered a chip on ebay, turned up in 2 pieces :(
Old Mar 2, 2012 | 05:40 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Ordered a chip on ebay, turned up in 2 pieces :(
Hi guys, i ordered a powerchips 195 chip from ebay, the user has good feedback but it arrived with the back off of it and a fair bit of silicone on the circuit board....
is this normal? bit worried.....i clipped the back on no problems and now looks ok again was just wondering, heres some pics:
And clipped back together easily enough:
What do u think?
Cheers Adam
Old Mar 2, 2012 | 05:44 PM
STeve's Avatar
Super Moderator
only way to tell if its ok is to try it I guess, both chips I had for the FRST were metal superchips style
Old Mar 2, 2012 | 06:07 PM
Adam.'s Avatar
Adam.
Yes i know the chips u mean mate, i put a post up asking about this chip before i ordered it:
https://passionford.com/forum/genera...-any-good.html
guess i will have to wait till tomorrow and see.
Old Mar 2, 2012 | 06:21 PM
Rsmat's Avatar
Rsmat
Would have thought it would be fine unless it looks damaged elsewhere.
Old Mar 2, 2012 | 06:22 PM
STeve's Avatar
Super Moderator
powerchips have a good rep so as said unless the board etc looks damaged I would not fret
Old Mar 2, 2012 | 06:28 PM
Adam.'s Avatar
Adam.
No the board etc all looks fine, so will give it a try first i suppose :s
Old Mar 2, 2012 | 07:09 PM
Jim Galbally's Avatar
Jim Galbally
just to check, you know you need other supporting modifications to run a 195 powerchip? you cant just clip it in a standard FRST?
Old Mar 2, 2012 | 07:10 PM
Jim Galbally
hold on a sec ive just seen your spec... CVH35, T3, and a 1.8 ZVH?
the map on that chip will not be right!
best case it runs poorly
worse case the engine melts
Old Mar 2, 2012 | 07:40 PM
Adam.'s Avatar
Adam.
195 chip, uprated fuelpump and beiges? which are meant to work together?
im not running above 14psi which is suitable for standard pistons on a 1.8 ZVH?
and the car is always mapped by power engineering before its drove and will be off their first.
my understanding is, if i want to run more boost, its forged pistons or management....why do u think its due to melt? it idled and ran fine (round the block) on a non suited 165 superchip....just interested...top end or something else, as said i always map the car once i have done engine work.
Old Mar 2, 2012 | 09:29 PM
The Youth.'s Avatar
The Youth.
It's not getting mapped by power engineering it will be getting the fueling checked, big difference m8 the map is in that chip!
steve
Old Mar 2, 2012 | 09:33 PM
wildheart's Avatar
wildheart
Plus correct me if im wrong,There is only 2 places in britain that can map frst's and power engineering isnt one of them.
Old Mar 2, 2012 | 09:36 PM
Rsmat's Avatar
Rsmat
He's just worded it wrong guys... Cool down..
Old Mar 3, 2012 | 06:48 AM
Adam.'s Avatar
Adam.
Yes sorry i meant fuelling and boost checked
Im interested to know in what way this chip isnt suitable seeing as its 195 spec?
CheeRS Adam.
Old Mar 3, 2012 | 08:30 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Because its the spec of the chip not the spec of your car
If the same way that you can fit a different sized door into the standard opening, it requires some buggering about before it's sorted, and you may find that urging the correct door in the first place is the cheapest option in the log run
Old Mar 3, 2012 | 08:36 AM
Adam.'s Avatar
Adam.
Thans for that Dojj, so the chips scrap? or is their a way round this?
Old Mar 3, 2012 | 11:45 AM
phil_rs's Avatar
phil_rs
yam yammer
I think what people are getting at is, that chip is designed to be run on a 1.6 cvh not a 1.8 zvh, therefore the map may be wrong
Old Mar 3, 2012 | 04:36 PM
dojj's Avatar
dojj
Get your car to pe and get them the sep the chip to see if it's suitable, don't swap the chip and then drive it there
Old Mar 5, 2012 | 03:30 PM
Jim Galbally
as above, the issue is the TURBO is different and so is the capacity.
these 2 things will affect the requirements and therefore the MAP on the chip will be wrong.
dont get me wrong the car will start and drive, but it could also potentially melt!
dont bin the chip, the hardware itself is worth 75quid! you just need somewhere to remap it.
the only place i KNOW can do this is motorsport developments. grove garage MIGHT be able to do it, but i heard his equipment got nicked.
probably a few more places in the UK but i dont know of them.
AFAIK PE dont have the equipment to do this.
Old Mar 5, 2012 | 05:09 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
chips liek this are usually 'off the shelf'
so yours is suitable for an efi turbo with certain things added to it
therfore if you fit it with higher boost etc you will need the fuel to match and without it you will melt a piston or 2 or 4
to be honest ive run a few zvh's on 'off the shelf' chips for cvh and its been fine but thats no proof yours will be, i figured whats 200 cc's at 18psi lol
get your wallet out, big port/valve head, fancy turbo, and a few other bits and you are talking some good power
course it wont stop there and you will soon want forged big end rebuild, bigger turbo, alloy fancy bits and when you turbo round you have 10 grand in you bay
The Underdog
29
Sep 7, 2015 09:49 PM
jamie956
Sep 1, 2015 10:50 AM
ray barker
Aug 7, 2015 09:00 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
