Engine Head Removal
Old Jan 22, 2012 | 12:41 PM
Jasoncmor's Avatar
Jasoncmor
Default Engine Head Removal
Hi all.
If I need to replace the headgasket on my car, Mk4 fiesta 1.25, Obviously I'd need to remove the head, but how do you lock the cams into place?
I'm assuming you'd need to remove the cam belt? Because the cams are attached to the head?
Would the locking plate used for when changing the timing belt be ok, or would you need something else?
Cheers, Jason
(sorry for asking so many questions, I'm just trying to learn more about my car)
Old Jan 22, 2012 | 12:55 PM
LukeDaisley's Avatar
LukeDaisley
yes you are correct its the 5mm ruler looking plate and a pin in the side of the block to time the bottom end.
Old Jan 22, 2012 | 12:57 PM
Jasoncmor's Avatar
Jasoncmor
Thanks for clearing that up.
RUBY123
Oct 22, 2023 12:04 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
