Focus RS Mk1 Gearbox Pictures?
Old Jan 20, 2012 | 04:41 PM
thielt1's Avatar
thielt1
Default Focus RS Mk1 Gearbox Pictures?
Does anyone have any pictures of the gear selector mechanism bolted to the top of the focus RS mk1 gearbox?
I will be running the shift tower and cables from the mk1 frs and I was wondering if I would need to buy the actual gear selector as well.
Thanks!
Old Jan 20, 2012 | 05:13 PM
nevsrevs's Avatar
nevsrevs
look at my build thread, [focused on track zetec turbo] i stripped ours down
Old Jan 20, 2012 | 06:16 PM
thielt1's Avatar
thielt1
I am actually already subscribed to your thread The pictures I need are too small on your thread and they are hard to distinguish with the black paint. Could you post up some larger pictures? Build looks great by the way. I will also post up some pics of what I need.
Old Jan 20, 2012 | 07:32 PM
nevsrevs's Avatar
nevsrevs
do you mean are the towers interchangable? cos they are, i will try and sort some bigger shots out,
Old Jan 20, 2012 | 07:36 PM
thielt1's Avatar
thielt1
What I am wondering is if the Gear Selector mechanism that is mounted to the top of the FRS Gearbox is the same as the standard MTX75. I know that the actual shift tower with gear knob and shift cables are different.
Old Jan 20, 2012 | 07:51 PM
nevsrevs's Avatar
nevsrevs
i know its not great,
photo-47.jpg?t=1327092653
Old Jan 20, 2012 | 07:55 PM
nevsrevs's Avatar
nevsrevs
cant see them being any diff, really, but not 100 percent
Old Jan 20, 2012 | 08:17 PM
thielt1's Avatar
thielt1
I hope not because I really don't want to import a whole FRS gearbox! Thanks for the pic!
Old Jan 20, 2012 | 08:21 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
they're the same across the range of mtx75 with cable shifters and rear starters/hydraulic clutches IIRC, my frs box looks the same as the one in the pic.
Old Jan 20, 2012 | 08:27 PM
nevsrevs's Avatar
nevsrevs
good luck, bit of trial and error i thnk, should be ok though, i have swapped diesel to petrol over befor
Old Jan 20, 2012 | 08:41 PM
youngben's Avatar
youngben
not the best but few different angles
thielt1's Avatar
thielt1
That would be great and mean I only have to buy the tower and cables!
Old Jan 20, 2012 | 08:42 PM
thielt1's Avatar
thielt1
Perfect, I will look this weekend and post some pics of the standard box so everyone has a reference.
Old Jan 23, 2012 | 01:30 PM
thielt1's Avatar
thielt1
Here are the pics, sorry the gearbox is a little dirty but it is being redone.
Old Jan 23, 2012 | 01:32 PM
thielt1's Avatar
thielt1
what do you guys think?
Old Jan 23, 2012 | 03:31 PM
nevsrevs's Avatar
nevsrevs
the same as mine, running 2.0 cables, square rubber block on 1, and ball clip on the other, should be fine
Old May 12, 2017 | 05:42 PM
t230's Avatar
t230
i hate jacking these old threads but its the easiest as i wont have to waste time explaining myself so i hope you all dont mind!
i have transplanted my MTX75 with LSD to my FRS MK1 shell from the T250 Focus....BUT no matter how i connect cables or whatever adjustment...i cannot select gears!!! it seems neutral is up and down WTF is wrong lol??
Gearbox is fully functional...car it came from was fully working low mileage daily so i kno 100% working , has brand new paddle clutch , cylinder etc.....
when i connect the 'white' cable it only connects in gear and NOT in neutral.....but cannot get it out of gear at ll (tried starting it etc)
clutch has been bled properly....
one more thing the spring inside the white cap where it holds on to the bracket is loose but i can still screw it together - does this mean the cables are effed??
Anyone be kind enough to explain the correct procedure for connecting these up?
got soooo pissed off threw one of my axle stands but it landed perfectly and i couldn't even muster the skill to smash something thats how bad things went today LOL
my last option is to rip out gear cables from RS and just wack in my T230 short shifter cables....man im getting so pissed of with fucking about with cars....specially since my op i just dont have the energy i just wanna get in my ca and effing drive it looool
cheers people any help always appreciated.
Old May 12, 2017 | 05:50 PM
studabear's Avatar
studabear
What gearbox did the t250 focus have?
Old May 12, 2017 | 06:06 PM
Dubs44's Avatar
Dubs44
you need to use the cables and shifter that are compatible with the selector on top of the gearbox or it won't work, i had exactly the same problem when i tried to use a 2.0 petrol mtx75 and 1.8 diesel shifter and cables, they wouldn't work together so had to buy the 2.0 petrol cables and shifter to make it work.
Old May 12, 2017 | 09:06 PM
studabear's Avatar
studabear
I've just tonight hooked up my focus rs gearbox in my escort mk4 gear stick and linkage. I've used a tdci focus gearstick and cables. Seems absolutely fine will prob just need slight adjustment once the engine is running.
Edit to add my connections at the gearbox are a bit different to the pics earlier in the thread.
Old May 13, 2017 | 07:55 AM
t230's Avatar
t230
T250 has/had (and will again not killing it off ) MTX75 with LSD
LADS - I love you guys...always come though - yep i have a choice of B&M Shifter from T230 or standard height shifter from T250....
enjoy the sun if you hav any today!
Old May 14, 2017 | 08:16 AM
Gadget's Avatar
Gadget
Spanner monkey
I've had two brackets from Fords so far, they both held the cables at completely the wrong angle to connect onto the selector mechanism! Got a third on order now so fingers crossed!
Old May 14, 2017 | 09:31 PM
studabear's Avatar
studabear
It looks like my frs box has the shift mechanism from a tdci focus. So I got the gear stick, cables and the gearbox bracket all from the same car.
Old May 15, 2017 | 11:37 AM
Churtz's Avatar
Churtz
Is it all sorted now then? I believe I have a focus RS shift tower in my box of spares that may be for sale if required.
Just let me know.
Matt
Old May 15, 2017 | 12:30 PM
studabear's Avatar
studabear
I think im sorted, can get all gears except reverse, but I expect I will be able to get that once the engine is running again. Can't get oil in the box yet as haven't got the drain plug
Old May 17, 2017 | 10:14 PM
massivewangers's Avatar
massivewangers
I've been having a similar problem. I've got a Focus MTX75 box in an Escort. I can only get 1st, 2nd and 3rd and it takes some effort. The cables all connect up ok, but it doesn't seem to select gears at all well.
Old May 17, 2017 | 10:30 PM
McCloud 85's Avatar
McCloud 85
Not sure if this helps but difficulty or tightness to select gears can be caused but how the cables are run. If they have too many bends or are too tight the gears will be really tough to select. We had an issue on my brothers puma where you would miss gear selection whilst driving and it was all down to the cable route.
Hope that helps.
Old May 19, 2017 | 10:52 PM
massivewangers
Hope that helps.
I have wondered about this. I wondered if they are a bit twisted or something. I have tried to keep the routing as straight as possible.
For reference, this is what my box/cable/selector looks like:
This is the gear lever in mine (I have since made some mounts and bolted it down a bit more solidly!):
A friend of mine had some gear selection troubles when he had put a Focus gearbox in a MK5 Escort. He ended up crushing the rubber mounts where the gear lever bolts into the car. The excess play in them was causing problems.
Sadly I did buy the gearbox, cables and lever separately, so I have no idea if they're the right ones. I wouldn't have thought the other cable design would fit though.
Old May 24, 2017 | 06:22 PM
t230's Avatar
t230
Ive just swapped gearlinkages - drove to stutgart and back in the FRS - Simpleh Luvleh....
but now a new can of tuna! The same mtx75 box in the 250 driveshafts kept popping out...i put this down to the driveshafts...but now the same is happenening with FRS shafts...
is my gearbox diff def shagged?? cheers all!
Old May 24, 2017 | 09:13 PM
studabear's Avatar
studabear
Nearside or offside? Wouldn't think the offside long shaft could pop out as the bearing carrier should keep it in. Is the nearside shafts circlip ok?
Old May 24, 2017 | 09:21 PM
massivewangers
As above, I would think that the offside would be ok due to the bearing carrier. If it was nearside, did you fit a new spring clip when you fitted the shaft? My car suffered from a shaft popping out due to an old clip being used once.
Old May 25, 2017 | 07:00 AM
t230's Avatar
t230
cheers for the reply
is happening with two different sets of shafts (standard foci and RS) - but no i havent tried a new spring...apart from splines does anthing else need to line up or does the driveshaft just push in?
Old May 25, 2017 | 09:58 AM
massivewangers
It should just push in and then the spring clip should effectively lock it into place. It can be a bit of a twat to get the shaft in far enough for the spring clip to engage though. When I fitted mine, it took a bit of force to get it to pop into place.
It may be worth trying a new clip. Also, though this is unlikely given that it's a Focus and using Focus parts, it might be worth checking the drive shaft plunge. So fit the shaft, but not the hub retaining nut. Then, with the suspension assembled, try pushing the shaft through the hub to fully compress the inner tripod joint. I don't know what the plunge figures are for a Focus to be honest but, if you loosen the inner boot, it should show you if the driveshaft looks stretched at all.
Old May 25, 2017 | 09:15 PM
t230's Avatar
t230
right , rear coilovers sorted , exhaust leak stopped, so i ll crack on with this tmmrw....
rs driveshafts SHOULD fit MTX75 standard gearbox with.....(dumb question i know )
Old May 27, 2017 | 05:07 PM
t230's Avatar
t230
ok so what i did was remove the gator , tap in the end of the shaft , refit gator (no grease lost) and test drive. Drove to Guildford and back to collect some rear hubs from ST breaker so far so good no more gearbox oil leaking out. thank you all for the replies.....
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
