an hour on the rollers today
Old Jan 11, 2012 | 05:52 PM
mgtkr1's Avatar
mgtkr1
Default an hour on the rollers today
after fitting -31, and having little joy setting up boost via bleed valve i refitted amal, using diagram of cossie page as i wanted to be sure it went on right. i noticed a nylon insert, is this a ''jet''. anyway car hit 15psi and in 1/2/3rd was quite awesome, and my dodgy recaro slid back 6 inches!! anyway, rather than push my luck i thought better of it til its set up. booked an hour at a local dyno operators (i live near brigg) and was told the car sound fantastic, hold boost ect but was lean up top. will need more dyno time to make safe alternatively a chip from bayjoo. that was his suggestion. for a guy who's been around some nice motors ie racing tr4/6's the sight/sound of my turboed bonus seemed to please him. no problem with the proprieter. admitedlly they dont seen mfi much these days but one thing niggles me. in certain areas, i seemed to know more about rst on mfi!! for example, the 2 employees were poking around at plugs ect and one asked, whats the green plug? i said its a knock sensor to which he replied it cant be, its in the wrong place AND the car is too old his mate bluntly said dont talk wet, its gonna pick up knock were it is or words of that effect. anyway, ill be clear i want the propieters watching over in future, is tis acceptable? i can tell he knows old fords just by talking to him.
Old Jan 11, 2012 | 06:05 PM
Rsmat's Avatar
Rsmat
Is it a 4x4 you have mate...?
Old Jan 11, 2012 | 06:52 PM
He is on about mfi matt so it could be a Escort turbo ?????
Have you got a good power supply to your fuel pump.
Old Jan 11, 2012 | 07:10 PM
Rsmat's Avatar
Rsmat
Sorry didn't read it all.
Old Jan 11, 2012 | 07:12 PM
mgtkr1's Avatar
mgtkr1
no matt, escort rs turbo in bonus shell.
Old Jan 11, 2012 | 07:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If he suggests a Bayjoo chip to sort the fuelling then he doesnt know what he's talking about! Any MFI chip will simply remove the boost cut (some also alter the spark adv curve but not many), fuelling is set by adjusting the EMFPA on the side of the metering unit.
Old Jan 12, 2012 | 04:28 AM
No bother matey.Its normaly me who cant read.Im thick as shit some times lol.
Old Jan 12, 2012 | 04:41 AM
mgtkr1's Avatar
mgtkr1
well tbh karlos, thats how ive always thought fuelling is setup, via metering head. ecu is purely to remove boost limit. they also said the backfire was prob boost cut, at 15psi!! this was prior to the run on the rollers but it turned out to be lean. hence the backfire. the owner seemed to know a bit and suggested a chip AND fuelling setup, not using a chip to magiclly get the fuelling to suit whatever boost is run although i can se how its interpreted. its only one of the employees that made me have initial doubts. no real benefit in a chip if it can hit 15psi then? do boost gauges lie to THAT extent?? i could do with visiting one of the ford specialists really, someone who deals with m.f.i regular
Old Jan 12, 2012 | 12:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Boost cut on a stock ECU is about 10psi so unless your gauge is really out it sounds like it could already be chipped mate, whip it out and have a look (silver ECU not the black one), take the back off, remove the metal plate covering the biggest chip in inside and stick a pic up on here.
You would be better going to someone who really knows RST's in and out, bit risky if he gets it wrong.
Old Jan 12, 2012 | 01:01 PM
mgtkr1's Avatar
mgtkr1
ill have a look and get a pic up mate. ill get an rst master to have a look next time, dont want anyway meltdowns!! prior to the actuator been replaced with a -31 it was at a lopwly 6psi on the gauge. i think it must be chipped, ill look anyway and hopefully we can see who by.
Old Mar 9, 2012 | 09:22 PM
GVK.'s Avatar
GVK.
Is it chipped?
Old Mar 9, 2012 | 09:33 PM
mgtkr1's Avatar
mgtkr1
it is chipped mate. not sure by who though. all i know is it goes way beyond the boost cut, cutoff. ive since had the fuelling setup and have 12psi and 15psi on demand (crude toggle switch/amal valve affair!!). im going to get a bayjoo chip in the future though. been getting a missfire occasionally albeit a loud as fuck one so reckon either the plugs need replacing/gapping or the dizzy is tired. only does it when under load ie low engine speed/high gear (4th) and letting it pull through to the effective powerband. goes pop just prior to the start of the usable power, then all is well. timing/fuelling is spot on.
Old Mar 10, 2012 | 07:01 PM
nickscunny's Avatar
nickscunny
Was it Vessey's you went to??
Old Mar 10, 2012 | 07:09 PM
mgtkr1's Avatar
mgtkr1
it was vesseys nick. it appears my gauge is out and my ecu isnt chipped. sometimes it allows higher boost, depending on how the power is applied. tbh, im pleased with the setup done by dennis. the car feels transformed when running less boost. a bayjoo chip is on the cards and another setup. apparently vessey did rst's on a regular basis but hardly see's them now. still, while there things went well and he hasnt forgotten how things work with mfi.
Old Mar 10, 2012 | 07:12 PM
nickscunny's Avatar
nickscunny
Yea I had mine set up at Vessey's also. Nicholsons at Crowle is a good one also, they have a proper Rolling Road. Did you join FordSport?
Old Mar 10, 2012 | 07:13 PM
mgtkr1's Avatar
mgtkr1
i didnt mate, hotmail was playing up. ill give it a go now mate
Old Mar 10, 2012 | 07:16 PM
nickscunny's Avatar
nickscunny
Ok mate....
Old Mar 10, 2012 | 07:27 PM
mgtkr1's Avatar
mgtkr1
just joined up on fordsport now mate.
Old Mar 10, 2012 | 07:32 PM
nickscunny's Avatar
nickscunny
ta... Will you do me a favour and Private Message me your phone Number across? Trying to fire my turbo up and she aint playing ball.... Could do with a fresh set of eyes!
Old Mar 11, 2012 | 06:36 AM
mgtkr1's Avatar
mgtkr1
ok mate, pm'd you
A.t.p
Oct 23, 2015 07:54 PM
muzzman1
Sep 30, 2015 08:59 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
