how to get more power without lag?
Old Jan 4, 2012 | 01:02 AM
pip7rs's Avatar
pip7rs
Default how to get more power without lag?
as in the title im looking to get more power out my 4x4 cossie without gettin more lag from it spec as it is:
t34 with 63 housing
dark greens
s/s exhaust
standard 4x4 intercooler
4x4 exhaust
baileys breather kit
the car is surprisingly quick and beats cossies running geys and all your scoobs n evos etc but i just want more power without getting more lag if its possible lol thinking of 55 siemens and a chip but think am gonna need to fit a rs500 intercooler wich i know will give me lag
had the car running a 2wd exhaust manifold when i fitted the t34 but it drove shit and the lag was real bad so went back to the 4x4 and its nite and day
any suggestions are welcome if you know what i am trying to achieve
Old Jan 4, 2012 | 01:26 AM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
RS 500 cooler, 2wd manifold then anti lag chip lol
Someone will have a better idea than me as im half asleep... its 2.30
Old Jan 4, 2012 | 01:37 AM
pip7rs's Avatar
pip7rs
lol yeh that would work a treat but dont have that kind of money for a turbo that would handle anti lag but yeh simple and affective
Old Jan 4, 2012 | 08:38 AM
Marc sierra's Avatar
Marc sierra
Aren't you a bit limited by the dark greens when having a T34.63? I wouldn't risk running that turbo on full power with those injectors...
I would go for 55 siemens with a chip that suits them and a 500 cooler.
Old Jan 4, 2012 | 08:59 AM
R4N SS's Avatar
R4N SS
as above - bin the green and get the 55's with a decent cooler
Old Jan 4, 2012 | 09:15 AM
botters's Avatar
botters
competant bodger
ive got 500 cooler and never noticed any massive amounts of lag from fitting it
Old Jan 4, 2012 | 09:27 AM
Yeh im the same i fitted my bigger intercook and didnt notice any lag.
Old Jan 4, 2012 | 09:28 AM
It defo felt quicker with the cooler on.
Old Jan 4, 2012 | 09:56 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Im going to send your comments to Andy Forrest & Simon Norris they are wasteing their time when a lightly modded Cossie is quicker . My Cossie on greys ran 183mph & yours would beat it WOW!!! your right that would be surprising . Talk facts not fantasy please lad.
Old Jan 4, 2012 | 10:03 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
As said fitting a 500 style intercooler wont make any noticeable difference to lag but it will help with a few more bhp.
Steve
Old Jan 4, 2012 | 10:07 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The difference in lag with a bigger cooler is tiny, you wont notice it.
If you want a significant hike in power though, try moving to a GT3071 or similar turbo.
You'll slightly increase the boost threshold (ie the number of rpm you need to be doing before the turbo spools) but it shouldnt have anymore lag (the time taken to build boost during the boost threshold when going from almost closed to fully open throttle)
What chip are you running? how much boost do you run?
Its possible your current hardware (other than injectors) has another 50bhp left in it.
2wd manifold shouldnt cause any notable change in lag from the 4wd one and is capable of flowing more gas (ie can make more power) ultimately, you must have had some other problem when you fitted one.
Old Jan 4, 2012 | 10:10 AM
scoooby slayer's Avatar
scoooby slayer
t34 with 63 housing
dark greens
s/s exhaust
4x4 exhaust
for a start you cant be running max boost on a standard intercooler so get that changed and crank it up to 2 bar. the ammount of air an engine consumes filling up the little space in a bigger intercooler is fook all, it depends what you want your not gonna make 500 lbft, 500 hp on a yb at 3000 rpm its impossible, it is a choice go gt28 with mega response 300 hp or the sky is the limit but lag increases.
tbh if ur beating ybs on greys when ur on greens your motor is magic anyways lol
Old Jan 4, 2012 | 10:14 AM
pip7rs's Avatar
pip7rs
Always hot to be one tosser putting a comment on here and I am speaking fact not fantasy go on YouTube and see and if it makes you feel any better raped a saph running Siemens so while your in the subject what 1/4 mile did you run 183mph up fuck me that's a proper drag car lol
Old Jan 4, 2012 | 10:15 AM
pip7rs's Avatar
pip7rs
And the rest of you guys thanks for the advice think its gonna have to be Siemens and a rs500 cooler then if the lag ain't bad only option I really have lol
Old Jan 4, 2012 | 10:18 AM
R4N SS's Avatar
R4N SS
go for an airtec 70mm cooler as they are going cheap now good bit of kit too
Old Jan 4, 2012 | 10:20 AM
pip7rs's Avatar
pip7rs
Lol fair comment I'm running about 23psi but yeh I know I can't run anymore boost without an intercooler just wondering if I'd keep the quik spool and drivability with the intercooler and Siemens And to be fair is rather surprising no one believes it's stage 3 lol
Old Jan 4, 2012 | 10:23 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
A AB07 inlet Cam will help it Rev better as well, its about the best cam you can use without valve cutouts
Steve
Old Jan 4, 2012 | 10:26 AM
pip7rs's Avatar
pip7rs
Steve
Never really thought about cams I'll look into that cheers
Old Jan 4, 2012 | 10:31 AM
Chip's Avatar
Chip
Rod's best quarter is 11.7 I believe, not bad for a rwd saph at all but thats not really what his car is about of course.
His point that although pitched quite low still flew over your head was that whne you are claiming to beat "all your scoobs and evos" etc, is that there are loads of modified evos and scoobys that would absolutely destroy your car, I would go as far as to say that there are probably more that would than wouldnt now in fact.
350bhp or so (most you are likely to be running on your spec) just isnt really very much anymore sadly mate, so you must have only been picking on the very slowest from these other marques to race.
What quarter does your car do?
Old Jan 4, 2012 | 10:34 AM
gray_rs's Avatar
gray_rs
This car he is talking about is 1 quick car, it's also true about the 2wd manifold making a severe drop in performance, I'm changing from my greens to run seimens and a t38 just to hope to keep up with him, also away to use 4x4 manifold, myself and alot of my mates have been wondering what is done to his car to make it so fast and the noise from it is frightening, the boys who are saying it can't be so quick it's a fair comment because it shouldn't be with what it's running but honestly it's a fast fast car, it does 12.4 up crail 1/4 mile strip Consistanly all day , and that was a wet day .
Old Jan 4, 2012 | 10:47 AM
scoooby slayer
the time suggests he is a very good driver, theres a stage 1 skyline that does 11.6 consistantly around 114 mph, his terminal speed will be the indication of power, fair play though hes a good launcher, i only did 12.3 in my old skyline and that was almost 600 hp lol trap speed 123 - 126 mph though.
whats he trapping ?
Old Jan 4, 2012 | 10:51 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
whats he trapping ?
He said its 4x4, so if he as a real animal he could get that time, i would say @ about 108mph ?
Steve
Old Jan 4, 2012 | 10:53 AM
Rsmat's Avatar
Rsmat
I would go.. 55's... Air injectors.. Wasted spark... Airtec 70mm cooler... Have it mapped with a massive 2.2bar...
Or on the cheap 500 cooler and 55's
Old Jan 4, 2012 | 11:02 AM
scoooby slayer
Steve
thats what im saying mate a good launch and its possible, i can calculate roughly the whp if i know weight and terminal speed.
Old Jan 4, 2012 | 11:06 AM
R4N SS's Avatar
R4N SS
i reckon the box or diffs will break pretty soon if is hard launching it all the time
Old Jan 4, 2012 | 11:08 AM
pip7rs's Avatar
pip7rs
Weight would be standard and terminal speed was around 114 115 cheers
Rsmat's Avatar
Rsmat
Like chip says... At that sort of boost on a standard cooler around 350bhp.
Old Jan 4, 2012 | 11:09 AM
Rsmat's Avatar
Rsmat
Beat me to it mate....
Old Jan 4, 2012 | 11:11 AM
pip7rs's Avatar
pip7rs
Thinking of just plug and play MSD chip and the cooler an injectors but yeh going wasted spark but not for performance just reliable with plugs lol cheers
Old Jan 4, 2012 | 11:17 AM
gray_rs's Avatar
gray_rs
God knows how that's not happened already ,
pip7rs's Avatar
pip7rs
Thinking of just plug and play mad chip and the cooler an injectors but yeh going wasted spark but not for performance just reliable with plugs lol cheers
Old Jan 4, 2012 | 11:18 AM
James @ M Developments.'s Avatar
The limiting factor of your current spec is the fuel injectors, they simply do not flow enough to push the turbocharger to its limit.
So a car with exactly the same spec engine, but with larger injectors fitted allowing it to run flat out, is never going to produce less power.
The next logical step for you is to jump up to a set of 55s, which will not make any more lag, as the turbcharger will remain the same, but it will be safe to run flat out at 32-34 psi peak tailing as rpm increase.
You would need an 044 fuel pump, chip to suit and a set of 55s. aswell as a large intercooler to keep acts safe and under control.
scoooby slayer
that would equade to roughly 320 whp, i wasnt expecting a terminal that high fair play
Old Jan 4, 2012 | 11:19 AM
pip7rs's Avatar
pip7rs
Lol only gets launched on the strip wich is once a year but yeh will happen just means a tow home n another diff lol sure well have some in stock
Old Jan 4, 2012 | 11:23 AM
pip7rs's Avatar
pip7rs
That sounds just exactly what I'm after the fuel pump was always a concern guess I should have gave u a call lol how much would it be for that set up inc wasted spark? Thanks
Old Jan 4, 2012 | 11:28 AM
You have a pm mate.
Old Jan 4, 2012 | 11:31 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im suprised at the terminal speed as well
Mine was doing the 1/4 @ 114.77mph with 370bhp (flywheel)
Steve
Old Jan 4, 2012 | 11:47 AM
pip7rs's Avatar
pip7rs
You have a pm mate.
Thanks mate will be in touch soon
Old Jan 4, 2012 | 11:58 AM
pip7rs's Avatar
pip7rs
Thanks mate happy with that for a lightly modded cossie just don't won't to go to daft power wise and affect the driving as its a good reliable car
Old Jan 4, 2012 | 12:22 PM
Chip's Avatar
Chip
If its specifically for the drag strip you want the extra power, just nitrous it, nothing else will come close to the gains for the money.
