Gasket between turbo and manifold, who uses one?
Old Dec 22, 2011 | 09:49 AM
rog's Avatar
rog
Default Gasket between turbo and manifold, who uses one?
The small square gasket that goes between the turbo flange and the place where it mounts onto the manifold.
Been having issues with this, before I got my car rebuilt it never ran one and I never had any issues, when I put it back together I decided to put one in, it lasted about 300 miles then melted, i bought/brought another one and it lasted an even shorter time before doing the same, they were both metal, so when I saw melted I mean it disintegrated and there was less than 1/4 of it left.
Do most people run without them?
Old Dec 22, 2011 | 10:18 AM
DAN400's Avatar
DAN400
i ve never ran with one and never had a problem,
nor has any off my mates
Old Dec 22, 2011 | 10:26 AM
RSLUBBY's Avatar
RSLUBBY
I have had over 20 cozzies over the years and never seen one on any of my turbos. I always finely sand the two faces after run for a few mins seals up itself lol
Old Dec 22, 2011 | 10:30 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If its a daily driven car not getting used hard and you are bothered at the slight bit of noise you tend to get from not running a gasket then use one, but IME they tend not to be reliable on cars getting used hard.
Personally I never use them anymore having had failures in the past when I have done so.
Old Dec 22, 2011 | 11:44 AM
Ridgey's Avatar
Ridgey
Never used one.
Old Dec 22, 2011 | 11:48 AM
ozmk1cos's Avatar
ozmk1cos
Thats handy info to know right now cheers
Old Dec 22, 2011 | 02:01 PM
cossie891's Avatar
cossie891
I have always been told never to use them
Old Dec 23, 2011 | 06:12 PM
BRAMMER's Avatar
BRAMMER
I've used one on every turbo i've fitted - got one on now and have never seen any fail, melt or cause any issues.
I have heard of loads of people saying now they don't use them like you do further down the 2wd manifold where it splits but i had issues here with sealing mainly due to the non standard bolts previously being used and failing out - but got the correct material ones in there now.
Old Dec 23, 2011 | 07:07 PM
WongRS's Avatar
WongRS
i put a cometic one on my t24, blew it within 10 miles, so guessed it was faulty, changed it again, and it lasted about 8 miles this time, took it off and ran without, not a problem since.
Old Dec 24, 2011 | 05:46 PM
BRAMMER's Avatar
BRAMMER
These are the metal ones where talking about here?
Old Dec 24, 2011 | 06:54 PM
WongRS's Avatar
WongRS
http://www.ebay.co.uk/itm/TURBO-MANI...item5d31a065bb
One of those?
Old Dec 24, 2011 | 07:38 PM
Ive heard a few bad things about fitting these too.
Old Dec 26, 2011 | 07:44 PM
rog's Avatar
rog
Thanks for the input everyone, confirms it for me. WongRS, yes thats the gasket I mean, not the same supplier though.
Old Jan 5, 2012 | 06:49 AM
BRAMMER's Avatar
BRAMMER
Right now i see, the one in question looks wrong - i have had this one fitted for to every turbo of mine without any issues what so ever
http://www.ebay.co.uk/itm/Garrett-T3...85481119067388
Old Jan 5, 2012 | 07:18 AM
NEIL A's Avatar
NEIL A
I would think your manifold or turbo flange is warped letting gasses pass and washing the gasket, i would lightly sand the faces and try a straight edge on them.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
Ade
Aug 31, 2015 06:41 PM
