Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Where Can i go To Sort Out Rust On My MK5 Fiesta Zetec s
Old Nov 21, 2011 | 07:40 PM
DannyZetec-sUnwin's Avatar
DannyZetec-sUnwin
Default Where Can i go To Sort Out Rust On My MK5 Fiesta Zetec s
basically what is says above do most garages to do it. is it expensive. any help wil be appreicated
Thanks
Dan
Old Nov 21, 2011 | 08:17 PM
bayfezza's Avatar
bayfezza
There's a place in Kent which is about Ł200 per corner but they do it properly.
You need it to be rolled and seam welded/sealed properly tho or it will rust straight away again. Best off asking any local places if they have done a mk5 before as i know quite a few people have had issues with garages not doing it the right way
Old Nov 21, 2011 | 08:58 PM
Escow-Van's Avatar
Escow-Van
Yes, most garages will do it.
It can be expensive if you want a 'like new' quality job involving buying panels, measuring, cutting, welding, filling, prepping, painting and polishing. A lot of hours would be involved.
If you want it to pass an MOT, patches are acceptable and obviously much cheaper. They can then use any old piece of steel sheet and blob some paint over it afterwards. Only problem is the rust will come back within a year or so.
Best to work out exactly what you need then call a few places and ask for a quick quote.
Old Nov 22, 2011 | 05:55 PM
DannyZetec-sUnwin
cheers guys both very useful answers
Old Nov 24, 2011 | 04:43 PM
sheeks's Avatar
sheeks
while your at it, check the inner rear wheel arches < mine where total rotten and failed its mot for this reason, just whip the rear panels inside of for a look.
Old Nov 25, 2011 | 09:42 PM
DannyZetec-sUnwin
i will do bud thanks alot
Old Feb 29, 2012 | 04:35 PM
Brendan's Avatar
Brendan
struggling with reality
moorlanc clasic cars near macclesfield / Leek. will do an amazing job!
JoeyBoyden
Jan 4, 2024 02:36 PM
Bailes1992
Sep 3, 2015 02:17 PM
borboyous
Aug 22, 2015 11:17 AM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
