ST200 FSE Power Boost Valve
Old Nov 20, 2011 | 04:01 PM
blakey100's Avatar
blakey100
Default ST200 FSE Power Boost Valve
Hi
I have just purchased a second hand fse power boost valve off ebay. Iv always wanted one and this one popped up, only problem is no fitting instructions. Can any one help I can roughly work out how it goes just not sure on the bottom pipe it has me baffled. If anyone has any pictures of there one it would me most grateful cheers
Old Nov 20, 2011 | 04:06 PM
Oranoco's Avatar
Oranoco
Put it back on E-Bay mate, they are fucking shite and about as much use as a snooze button on a fire alarm. The standard Ford item is adjustable from memory and just upping the pressure is no way to achieve anything with fuel injection anyway. If the one you have on the car now is working, leave it well alone
Old Nov 20, 2011 | 04:23 PM
botters's Avatar
botters
competant bodger
as above, they have been known to cause engine fires also
Old Nov 20, 2011 | 04:42 PM
blakey100's Avatar
blakey100
i dident no they can cause fires, just feel sometimes it could do with some low down help in the rev range.
Old Nov 20, 2011 | 04:44 PM
12340987's Avatar
12340987
Simple breathing modifications would help, either a cone filter, or if your into standard looks, you can drill holes in the bottom half of the airbox tray and purchase a K&N panel filter to go inside the box.. stainless cat back exhausts work well on the V6s and sound immense too
Old Nov 20, 2011 | 04:50 PM
blakey100's Avatar
blakey100
it has s/s manifolds decat, s/s exhaust system, blue finn, sealed induction kit good plugs, ht leads just needs a little more
Old Nov 20, 2011 | 05:09 PM
Oranoco's Avatar
Oranoco
Get it on the rollers and see if all the tweeks are working well together. Is your stainless a quailty one or a Powerflow abortion?
Old Nov 20, 2011 | 05:13 PM
RS Grant's Avatar
RS Grant
Made in Scotland
LOL @ always wanting one.
Not sure you can go much further with your engine (staying N/A) to be honest... I'd suggest cams but not sure there are many out there which would give a decent gain per £ on an ST200.
As for the FSE Valve, bin it or sell it to some nobber that's spinning around with trays under his rear wheels down Maccers car park one night. It would be a pointless addition to your car IMO.
Cheers,
Grant
Old Nov 20, 2011 | 05:17 PM
gjh's Avatar
gjh
Ye get it checked out on a rolling road. You never know, you may have a little problem or it could be just in need of a good tune up. And while on the subject of dodgy mods, what the hell are ecotek valves meant to be good for?
Old Nov 20, 2011 | 05:19 PM
Chaz888's Avatar
Chaz888
Know what you mean the ST engine is very tame when down low have you tuned the throttle body dose a bit better with pick up ,and how have you routed the cold air feed to the filter? also thinking of a very light fly wheel myself as I think the engine lacks good pickup from low revs its only fault I would say ,and also if you fit the fuel reg thing you will find fords adaptive fueling will just dial out the extra fuel it detects.
Old Nov 20, 2011 | 05:23 PM
Oranoco's Avatar
Oranoco
Creating an air leak on the hose to the brake servo. Sounds like a great idea
Old Nov 20, 2011 | 05:37 PM
bookwyse's Avatar
bookwyse
First thing is fuck the blue fin off and get a decent remap. The bluefin is designed for a standard motor and using it with your mods will be causing issues.
Then get either a 220 or decent 75mm mustang throttle body on there and it will then have a much better pickup. As for the power boost I have a resistor chip and cooker knob that will work well with it. Lol
Old Nov 20, 2011 | 05:48 PM
Fiddy's Avatar
Fiddy
VERY difficult to get more power low down than you mods you have already. the 2.5 V6 is not renound for big power gains, the mods you already have are the best way forward. after that, the way forward is a supercharger conversion. whole kit to convert it is readily available in america, but its not cheap, and if you were contemplating that, my advice would be take that money, sell the 200, and buy a car that has good tuning capeabilty, because the V6 Duratec doesnt.
as for the boost valve, waste of time, will make matters worse, not better.
Old Nov 20, 2011 | 06:07 PM
Chaz888's Avatar
Chaz888
the 220 TB is the same size as the ST200 one and you could try going turbo if I can find a cheapish T3/T4 ,then Ill be going turbo!
Old Nov 21, 2011 | 07:48 AM
Oranoco's Avatar
Oranoco
Won't you need a turbo for each bank of 3 cylinders? Would think the engine would consume a large volume of compressed air. Not to mention complexities with the manifold and exhaust
Old Nov 21, 2011 | 09:19 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Which cats have you removed as there are three? It's better IMO to remove the pre-cats, and leave the main cat - or fit a decat and put it back on for MoT. You're wasting your time with the Bluefin, indeed any remap on the car is only going to account for very minimal gains.
As has been said it's difficult to extract more out of the 2.5 and you can find yourself spending hundreds to gain one or two bhp. A better bet would be to fit the 3.0 bottom end, or the complete ST220 engine.
Old Nov 21, 2011 | 10:52 AM
RS Grant's Avatar
RS Grant
Made in Scotland
I've just bought my second ST200 because when I'm back on road, it'll be fantastic at what I need it to do:
- Carry two Labradors with ease
- Transport me around come rain or shine
- Relatively cheap to run
- Has sufficient pace to make progress
- Well equipped & looks good (IMO)
- Makes a really good noise
...I don't understand why anyone would wank away hundreds/thousands trying to make it a car that it will never be. But everyone's different I suppose.
Cheers,
Grant
Old Nov 21, 2011 | 11:20 AM
DanW@FastFord
Spelling Club King!
Old Nov 21, 2011 | 11:33 AM
RS Grant's Avatar
RS Grant
Made in Scotland
Originally Posted by DanW@FastFord
Hahaha, I know your ST200 hurt your wallet mate but my first one was great and from the drive home, this one looks to return the same sort of MPG.
If something does go wrong then parts aren't mega pricey either, yeah there are £1500 cars which are cheaper to run but for a c150mph/200bhp, 2.5 V6 petrol, this isn't bad IMO.
Cheers,
Grant
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
cossirob
Sep 3, 2015 09:17 PM
