best stuff to remove chewing gum from carpets.
as above guys, found some and i tryed bu attacking it with the end ov the hoover, not recomended. any info appreciated.
on clothing, you wet the cloth and then put it into the freezer
the frost then freezes the gum and also separates it away from the material so it's just a case of unpicking it afterwards
not too sure about doing the same thing on a carpet though as it may give you a bigger problem when you have to clean up the damp patch
blimey that was quick, il try the ice tomorrow and see if i can find some plumbers freeze spray, cheers guys
guys i dont know what i would do without you
just tryed it on my dads spare (broken badly) car and it worked wonders. it is a bit of a pain to pick it off but it worked. thanks a lot guys.
Edit: it had been treaded in for atleast 6 months aswell.
Orion_Gav
Sep 29, 2015 04:50 PM
