Engine change
Old Oct 2, 2011 | 07:08 PM
Dudder41's Avatar
Dudder41
Dudder
Default Engine change
I have a 2006 fiesta zetec s and it has siezed up! I have a 56 plate 2l st engine and just wondering if it will fit stright in or is there mods you have to do to get it in?
Old Oct 2, 2011 | 07:12 PM
LukeDaisley's Avatar
LukeDaisley
it should be easy enough to do. drive train complete and ecu swap.
Old Oct 2, 2011 | 10:24 PM
Dudder41's Avatar
Dudder41
Dudder
I never got the ecu to go with it? Any chance i can get the 1.6 programed for that engine? Also my 1.6 had a screw on oil filter and the st has got paper filter will this be a problem?
Old Oct 3, 2011 | 01:09 PM
martysmartie's Avatar
martysmartie
That is not true, at least if the Duratec is the same style as the Zetec-E engine it replaced, you will most likely find the exhaust and inlet are on opposing sides? There probably are a lot of other things as well, i.e. is the gearbox different on the ST to the Zetec S engine which will be an IB5, will it fit?
Martin
Old Oct 4, 2011 | 04:01 PM
LukeDaisley
Martin
ford bell housing patterns will fit each other. but drive train includes the gearbox.
Old Oct 6, 2011 | 06:11 AM
paul-h's Avatar
paul-h
ST engine has a screw on oil filter mate. Box is an ib5 not sure what's on the 1600 engine though can't imagine it would be much different.
Old Oct 6, 2011 | 01:20 PM
martysmartie
Zetec S is IB5 as well
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
cameron2
Aug 25, 2015 07:18 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
