timing up my escort rs turbo S2
Could anyone give me a quick guide to doing it, from the start to finish, ive got a vernier and newmans phase 4 cam, my tuner said it will be fine to time it up to factory settings so im able to drive it to his garage then he will do the actual cam/vernier settings..So all I need is a couple of directions on it.
Thanks, Joe.
Thanks, Joe.
set the vernier to zero, on the head there is a dot directly above the cam, put the timing mark on the pulley to this, on the lower pulley is a groovd line this up with the largest of the three points on the timing cover, lever the tensioner over but not too hard an tighten it checking nothins moved, turn the engine 2 revolutins by hand and check again, if all is still good it will be fine, be warned tho yo may need a timng light for the distrubter if you have moved it
Got it all to what I thought was TDC but it's running like a bag of shit, I'm thinking maybe I'll have to undo all the Allen keys on the vernier and advance/retard the vernier until it sounds better..Good thing is it's up and running!
Any ideas/help is appreciated.
Thanks, Joe
Thanks, Joe
no, it came on the head that I brought..It's only so the car runs 90% to drive it to the garage to be setup properly, I won't be wanting to use all the power from the cam or anything..
Thanks, Joe
Thanks, Joe
Right, turns out ive made a big cock up..
I didnt know it because im not mechanic that ive got ARP headbolts, i didnt know they were a different torque to normal headbolts :/
All we have done is try and start the car, it started for about 4 seconds then stopped, since then we havnt been able to get it going again, tried starting it maybe 8 times or so..I rung my tuner and asked for the headbolt torques and he told me they are 93nm which is alot more than we done them to when we put the head on..
The question is, can i just torque the headbolts down to 93nm or should i get another gasket and start from the begining, i wont need my head skimmed again as it hasnt really been run apart from the 4 secs and turning over..
What do you guys advise? New gasket/Keep gasket and tighten up headbolts from where they are now..
We all make mistakes haha :/
Thanks, Joe
Thanks, Joe
the head bolts wont make it run like you say
do you have the plug leads on in the right order
sounds like you dont have the right fireing order or could even be 180* out
or its not timed up at at number 1 tdc
has to be spot on when timing it up as you dont have a dizzy
so you use these , tells you how to torque them
http://www.burtonpower.com/parts-by-...s/cv191hd.html
Ive got arp headbolts not ford stretch ones..I did the headbolts up to 60nm when i put the head on, then tried starting it etc and thought id ring my tuner to check the torque settings to be sure, and he came out with 93nm with arp bolts..which is like 70lbs or whatever..
what else does he get wrong
i think you have a timing issue or fireing issue
yeah none of the ecu plugs got taken out..Used the marks on the head with the mark on my vernier and a mark on the bottom pulley with the biggest triangle/tooth mark on the crank case/cover..
Think i may just go for standard gasket and headbolts, cant go wrong then can i?
try a standard cam pully on standard marks
take plug 1 out and put a long screw driver in the hole to check number 1 is a tdc then re look at the marks to double check
then check the leads are on in the right order
if it ran like shit and it wasnt timed up or the fireing wasnt right then you may have killed the plugs so take them all out and make sure they are dry and clean
that could and would stop it from re starting
Gave up on this for the winter and think I might try again, whilst timing up the engine with a mate I bent some valves and somehow the pots were full of water so when I turned it over, water shot out the plug holes when I took the spark plugs out, so I blew another headgasket whilst trying to get it running!! anyone know what could of happend? we made sure it was TDC etc..
maybe a cracked block?
Thanks, Joe.
Thanks, Joe.
Thanks, Joe.
Thanks, Joe.
i realy cant see how you have blown a HG just by terning it over
i think your best off taking it to some one with more experience
Well i dont understand how water can get into pot 2?
also i didnt mean i thought i cracked the block when turning it over i just thought that might be why there was water in pot 2?
it was a specialist garage that did it all which ended up blowing the gasket after a few hundered miles :/
Thanks, Joe
Thanks, Joe
There wasn't any water in there when I took the head off the first time, it got in there after we put the freshly
skimmed head on and tried timing it up and starting it...weird one :/
Joe
Joe
Billy_RS
16
Oct 11, 2025 09:41 PM
