MK5, MK6 pedal....? Pic inside,
Hi all,
My clutch is hard to disengage, with the clutch cable end spaced out a bit from its mounting plate i can just about use it, but its biting point is about a cm off the floor.
So i guess i need to do the infamous pedal mod.... question is, what have i got fitted (pic below) it has the bolt to adjust pedal height, i didn't think the mk4 had this from the factory, so has a previous owner changed something already.
Also, specifically what parts do i need for the conversion, I've read up about a few people using the mk5 pedal with mk4 quadrant.... how would this increase travel?
Cheers all
Rob,
Cheers all
Rob,
Its fitted with an abs clutch cable does any one know if the non ABS is shorter?
http://cgi.ebay.co.uk/Escort-RS-Turb...item2a05d494d2
and
http://cgi.ebay.co.uk/Clutch-Cable-F...item23115dab02
Rob
and
Rob
cable for cars with ABS is 1294mm
cable fo cars without ABS is 1248mm
These are for RHD cars as yours, Mine is LHD and the non ABS clutch cable was arround 30-35cm sorter! massive difference
That is the pedal conversion assuming the a mk5/6 quadrant has been used as well (should be white and cut down by 10 teeth IIRC), cable should be a single piece one not the two piece one, the bolt should give the adjustment as mentioned.
Thanks for the cable lengths, maybe i have fitted the wrong cable (too long)....
Rob,
That bolt is the only thing that has any effect on your biting point now, the quadrant simply holds the end of the cable and the bolt pushes against it, so the higher the pedal the more travel you will have on the cable.
True, i wondered if the sheath was the same length but the actual cable was shorter.... which might help me as the cable is very loose on the gearbox arm, quadrant first though
Rob,
Rob,
where the clutch fork is on the box threaded end slots through with a plastic D shaped bush. two nuts on the end so adjust up and lock off.
was thinking hydro but an adjustable cable sounds like less bother and more reliable to me. like i say need to look in to it a bit more.
Nice, i was going to go hydraulic but can be bothered at the moment, i don't fancy drilling my bulkhead at the moment either as its nice and original, maybe if the engine comes out again though as it would be nice and easy then.
Rob,
Rob,
MK5/6 setup doesnt use the ratchet either, hence the adjuster bolt in the above pics.
155lee
Sep 6, 2016 11:10 AM
