Help needed!
Old Jul 10, 2011 | 01:13 PM
superbikerider1's Avatar
superbikerider1
Default Help needed!
Hi all,
Looking at doing an underneath resto on my escort, what is the best way of removing all old paint/underseal? Is it a wire wheel on an angle grinder or something? Been looking at the resto section an everyone's doin it but not explaining how! Also, when it's stripped to metal, which order do I put the paint on! Primer then underseal then top colour? Or underseal first then primer as I've read a few people doin it different ways! This is my first ever resto an wanna do it right! Cheers!
Old Jul 10, 2011 | 01:39 PM
Russ Payne's Avatar
Russ Payne
Hot air gun and scrapper is how I did it mate, hard craft and then a wire wheel on an angle grinder or drill to get the last bit and then give it a clean with a rag and some thinners or petrol.
apply the primer, then stone chip if that what your using, then the paint
hope this helps
and good luck!
Old Jul 10, 2011 | 02:15 PM
Turbosimpsons's Avatar
Turbosimpsons
buy yourself a small sandblaster if you have a compressor. it will give you a good surface for your primer. etch primer, stone chip then paint.
Old Jul 10, 2011 | 02:36 PM
superbikerider1
hope this helps
and good luck!
Yeah I was thinkin it would be hard, but worth it when it's done! Thanks!
Old Jul 10, 2011 | 02:38 PM
superbikerider1
Gonna be doin it on axle stands in my not so big garage? Can you still use a small sandblasted like this? I will be on my back underneath the car? Sounds easier to get it off! Cheers
Old Jul 10, 2011 | 03:21 PM
Turbosimpsons
yes you can use them where you want. they do make a mess, but well worth it. you will still need a heat gun to remove the underseal.
Old Jul 11, 2011 | 01:56 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Originally Posted by superbikerider1
Hi all,
I did mine in axle stands last summer - all i used was this on a grinder and only cost me £4!! - goes through it like a knife through butter - and then a scraper and wd40 to loosen the awkward to get to bits.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
