temp gauge problem
Old Jun 6, 2011 | 04:56 PM
kevmc's Avatar
kevmc
Default temp gauge problem
My temp gauge isnt moving up when engine is getting hot it moves when turning on ignition on but dosent move at all after a long run but engine is very hot and fan dosent cut in either any ideas? Thanks
Old Jun 6, 2011 | 09:39 PM
kevmc's Avatar
kevmc
Anyone help me out on this?
Old Jun 6, 2011 | 09:51 PM
Ben26's Avatar
Ben26
double double check, which one goes where on the back, could be as simple as the wrong conector on
or take the ground off, it worked on mine for some reason
Old Jun 7, 2011 | 08:18 AM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Two things to check -
1) Check the connection on the temperature sender - single wire with a black push on plg (if its still there) attached to the temp sender at the front of the block.
2) Replace the temperate sender - easy job and only cost a few pounds from any local motor factors but make sure you take your old one when you change it as they are colour coded and need to make sure you get the right one.
Other than that there isnt much else that can go wrong really from that side of things.
Beyond that you need to check the wiring to the fan, fan switch could be faulty etc etc
Old Jun 8, 2011 | 05:44 AM
Turbo Al's Avatar
Turbo Al
on my efi 3i, when i switch the ignition on the temp gauge goes straight to half way then works its way up from there as the car gets hotter.
not long got the car and it has white dials fitted so im going with that.....maybe?
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Brickhouse
Sep 21, 2015 11:00 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
