Swedish Plenum is this worth it ??
just found this on ebay and wonderd if it would be worth buying one if it
would make that much of a performance difference ?
http://cgi.ebay.co.uk/COSWORTH-alli-...item41591f31b8
thanks
thanks
You might gain like 5bhp or so if you are lucky, but that will be the limit of it realistically.
they blow welds for fun and dont have equal airflow to all 4 cylinders (much like a standard plenum lol) if you want to upgrade get a small turbo escort plenum or a hart plenum if you really want to go for it, allthough if your not planning on 500+ bhp then stick with the 4x4 plenum you have and spend your money on something else
the swedish inlets work but only the r&b swedish or the mk swedish, the r&b ones are tried and tested by scs, theres a guy on here with scs built escos with 680bhp on a swedish inlet.... and i remember m k saying he was supplying a few tuners now
its the cheap shit on ebay and the diy'ers on here that get all the problems and people forget that the car needs a custom remap to suit
but at your power its not worth it mate..... needs to be high 400s + to even think about an inlet change
Rsmark, ALL large plenums effect throttle response, no matter who makes them.
Martin, I wouldn't bother tbh on your spec, the plenum on your car simply doesn't really need adressing.
although the hart inlet is the way to go.....
thats no good
