S1 ARB on a S2, anyone done it?
Basicly want to fit the S1 Anti Roll Bar onto my S2. Whats needed to fit it? Gearbox mount not a problem as ive a Focus RS box fitted and it mounts from above.
What TCA's do i use? S1 or S2? or are they the same? (going for the adjustable ones (Compbrake)).
The bolts on the front cross member, how many line up? Do i need to put anymore in?
If anyones got any pics of one fitted that would be alot of help
Matt
Matt
Just had the cross member changed but not for an s1, should had thought snout it before really. I got a s1 arb for cheep off a mate so will be sticking with that. Stu, what arb you using?
Yes,Matt, I run one on mine. You need to drill 3 new holes. Two in the front crossmember and one in the drivers side chassis. You will need to insert some metal tube in the crossmember to stop it crushing when the bolts are tightened. Best way to do this is drill the bottom hole to the right size then drill the top hole slightly bigger so the tube goes in then bolt it all together.
Rob,
RS1600i - Full, 1 piece aluminium front crossmember, thicker tie bars with slightly different ends, thicker ARB and toweye connected to the ARB clamp.
Series 1 - Cast iron 3 piece front crossmember, separate tow eye which connects to the ARB itself, thinner ARB and ties bars. All mounting points are the same as the RSi one though. Considerably heavier than the RSi.
Series 2 ARB
I'll let the pic do the talking
Yes, it did make alot of difference to the way the car felt on the road, handled and torque steered. The standard car felt unsafe even before hand. However, I also fully polybushed the car, just a better freshly rebuilt and re-jelled diff, good coilovers and MEF TCA's all set up to Fords own Tarmac Rally car specs so it's hard to tell just how much difference the ARB alone made.
Series 2 ARB
truffleshuffle
Sep 10, 2015 09:35 PM
saph in dorset
Aug 14, 2015 10:10 AM
